Build error with @arcgis/core and Angular 11: "Module parse failed: Unexpected token"
14387
13
07-01-2022 06:36 AM
turbolego
Build error using @arcgis/core with Angular 11:
Error: ./node_modules/@arcgis/core/core/has.js 5:101
Module parse failed: Unexpected token (5:101)
File was processed with these loaders:
 * ./node_modules/@angular-devkit/build-angular/src/babel/webpack-loader.js
 * ./node_modules/@ngtools/webpack/src/ivy/index.js
You may need an additional loader to handle the result of these loaders.
| See https://js.arcgis.com/4.24/esri/copyright.txt for details.
> let e;function a(a){return"function"==typeof e[a]?e[a]=e[a](globalThis):e[a]}e=globalThis.dojoConfig?.has||globalThis.esriConfig?.has?{...globalThis.dojoConfig?.has,...globalThis.esriConfig?.has}:{},a.add=(d,o,r,i)=>((i||void 0===e[d])&&(e[d]=o),r&&a(d)),a.cache=e,a.add("esri-deprecation-warnings",!0),(()=>{a.add("host-webworker",void 0!==globalThis.WorkerGlobalScope&&self instanceof globalThis.WorkerGlobalScope);const e="undefined"!=typeof window&&"undefined"!=typeof location&&"undefined"!=typeof document&&window.location===location&&window.document===document;if(a.add("host-browser",e),a.add("host-node","object"==typeof globalThis.process&&globalThis.process.versions?.node&&globalThis.process.versions.v8),a.add("dom",e),a("host-browser")){const e=navigator,d=e.userAgent,o=e.appVersion,r=parseFloat(o);if(a.add("wp",parseFloat(d.split("Windows Phone")[1])||void 0),a.add("msapp",parseFloat(d.split("MSAppHost/")[1])||void 0),a.add("khtml",o.includes("Konqueror")?r:void 0),a.add("edge",parseFloat(d.split("Edge/")[1])||void 0),a.add("opr",parseFloat(d.split("OPR/")[1])||void 0),a.add("webkit",!a("wp")&&!a("edge")&&parseFloat(d.split("WebKit/")[1])||void 0),a.add("chrome",!a("edge")&&!a("opr")&&parseFloat(d.split("Chrome/")[1])||void 0),a.add("android",!a("wp")&&parseFloat(d.split("Android ")[1])||void 0),a.add("safari",!o.includes("Safari")||a("wp")||a("chrome")||a("android")||a("edge")||a("opr")?void 0:parseFloat(o.split("Version/")[1])),a.add("mac",o.includes("Macintosh")),!a("wp")&&d.match(/(iPhone|iPod|iPad)/)){const e=RegExp.$1.replace(/P/,"p"),o=d.match(/OS ([\d_]+)/)?RegExp.$1:"1",r=parseFloat(o.replace(/_/,".").replace(/_/g,""));a.add(e,r),a.add("ios",r)}a.add("trident",parseFloat(o.split("Trident/")[1])||void 0),a("webkit")||(!d.includes("Gecko")||a("wp")||a("khtml")||a("trident")||a("edge")||a.add("mozilla",r),a("mozilla")&&a.add("ff",parseFloat(d.split("Firefox/")[1]||d.split("Minefield/")[1])||void 0))}})(),(()=>{if(globalThis.navigator){const e=navigator.userAgent,d=/Android|webOS|iPhone|iPad|iPod|BlackBerry|Opera Mini|IEMobile/i.test(e),o=/iPhone/i.test(e);d&&a.add("esri-mobile",d),o&&a.add("esri-iPhone",o),a.add("esri-geolocation",!!navigator.geolocation)}a.add("esri-canvas-svg-support",!a("trident")),a.add("esri-wasm","WebAssembly"in globalThis),a.add("esri-shared-array-buffer",(()=>{const e="SharedArrayBuffer"in globalThis,a=!1===globalThis.crossOriginIsolated;return e&&!a})),a.add("wasm-simd",(()=>{const e=[0,97,115,109,1,0,0,0,1,5,1,96,0,1,123,3,2,1,0,10,10,1,8,0,65,0,253,15,253,98,11];return WebAssembly.validate(new Uint8Array(e))})),a.add("esri-atomics","Atomics"in globalThis),a.add("esri-workers","Worker"in globalThis),a.add("web-feat:cache","caches"in globalThis),a.add("esri-workers-arraybuffer-transfer",!a("safari")||Number(a("safari"))>=12),a.add("featurelayer-simplify-thresholds",[.5,.5,.5,.5]),a.add("featurelayer-simplify-payload-size-factors",[1,1,4]),a.add("featurelayer-snapshot-enabled",!0),a.add("featurelayer-snapshot-point-min-threshold",8e4),a.add("featurelayer-snapshot-point-max-threshold",4e5),a.add("featurelayer-snapshot-point-coverage",.1),a.add("featurelayer-advanced-symbols",!1),a.add("featurelayer-pbf",!0),a.add("featurelayer-pbf-statistics",!1),a.add("feature-layers-workers",!0),a.add("feature-polyline-generalization-factor",1),a.add("mapview-transitions-duration",200),a.add("mapview-srswitch-adjust-rotation-scale-threshold",24e6),a.add("mapserver-pbf-enabled",!1),a.add("mapimagelayer-popup-identify-max-tolerance",20),a.add("heatmap-allow-raster-fallback",!0),a.add("heatmap-force-raster",!1),a("host-webworker")||a("host-browser")&&(a.add("esri-csp-restrictions",(()=>{try{new Function}catch{return!0}return!1})),a.add("esri-image-decode",(()=>{if("decode"in new Image){const e=new Image;return e.src='data&colon;image/svg+xml;charset=UTF-8,<svg version="1.1" xmlns="http://www.w3.org/2000/svg"></svg>',void e.decode().then((()=>{a.add("esri-image-decode",!0,!0,!0)})).catch((()=>{a.add("esri-image-decode",!1,!0,!0)}))}return!1})),a.add("esri-url-encodes-apostrophe",(()=>{const e=window.document.createElement("a");return e.href="?'",e.href.includes("?%27")})))})();export{a as default};
 @ ./node_modules/@arcgis/core/geometry/Geometry.js 5:200-223
 @ ./node_modules/@arcgis/core/geometry/Polygon.js
 @ ./src/app/features/header/title/senterlinje/senterlinje.component.ts
 @ ./src/app/app.module.ts
 @ ./src/main.ts
 @ multi ./src/main.ts
Error: ./node_modules/@arcgis/core/config.js 5:125
Module parse failed: Unexpected token (5:125)
> import"./core/has.js";import{deepMerge as e}from"./core/object.js";const r={apiKey:void 0,applicationUrl:globalThis.location?.href,assetsPath:"",fontsUrl:"https://static.arcgis.com/fonts",geometryServiceUrl:"https://utility.arcgisonline.com/arcgis/rest/services/Geometry/GeometryServer",geoRSSServiceUrl:"https://utility.arcgis.com/sharing/rss",kmlServiceUrl:"https://utility.arcgis.com/sharing/kml",portalUrl:"https://www.arcgis.com",routeServiceUrl:"https://route-api.arcgis.com/arcgis/rest/services/World/Route/NAServer/Route_World",workers:{loaderConfig:{has:{},paths:{},map:{},packages:[]}},request:{crossOriginNoCorsDomains:null,httpsDomains:["arcgis.com","arcgisonline.com","esrikr.com","premiumservices.blackbridge.com","esripremium.accuweather.com","gbm.digitalglobe.com","firstlook.digitalglobe.com","msi.digitalglobe.com"],interceptors:[],maxUrlLength:2e3,priority:"high",proxyRules:[],proxyUrl:null,timeout:6e4,trustedServers:[],useIdentity:!0},log:{interceptors:[],level:null}};if(globalThis.esriConfig&&(e(r,globalThis.esriConfig,!0),delete r.has),!r.assetsPath){const e="4.24.5";r.assetsPath=`https://js.arcgis.com/${e.slice(0,-2)}/@arcgis/core/assets`}r.baseUrl&&console.warn("[esri.config]","baseUrl has been replaced by assetsPath"),Object.defineProperty(r,"baseUrl",{set(){console.warn("[esri.config]","baseUrl has been replaced by assetsPath")}}),r.request.corsEnabledServers=[],r.request.corsEnabledServers.push=function(){return console.warn("[esri.config]","request.corsEnabledServers is not supported and will be removed in a future release. See http://esriurl.com/cors8664"),0};export{r as default};
 @ ./node_modules/@arcgis/core/core/Logger.js 5:0-28 5:1704-1705 5:2048-2049 5:2060-2061
 @ ./node_modules/@arcgis/core/geometry/Point.js
 @ ./src/main.ts
Error: ./node_modules/@arcgis/core/core/accessorSupport/tracking.js 5:1286
Module parse failed: Unexpected token (5:1286)
> import"../has.js";import t from"../Logger.js";import{pathToArray as n,getProperties as r}from"./utils.js";import{Flags as e}from"./tracking/Flags.js";let o,i=[];const c=t.getLogger("esri.core.Accessor");function s(){i=[]}function l(t){void 0!==o&&o.onObservableAccessed(t)}let a=!1,f=!1;function g(t,n,r){if(a)return p(t,n,r);d(t);const e=n.call(r);return m(),e}function u(t,n){return g(void 0,t,n)}function p(t,n,r){const e=a;a=!0,d(t);let o=null;try{o=n.call(r)}catch(i){f&&c.error(i)}return m(),a=e,o}function d(t){o=t,i.push(t)}function m(){const t=i.pop();o=i.length>0?i[i.length-1]:void 0,void 0!==t&&t.onTrackingEnd()}function y(t,n){if(n.flags&e.DepTrackingInitialized)return;const r=f;f=!1,n.flags&e.AutoTracked?p(n,n.metadata.get,t):h(t,n),f=r}const A=[];function h(t,r){r.flags&e.ExplicitlyTracking||(r.flags|=e.ExplicitlyTracking,p(r,(()=>{const e=r.metadata.dependsOn||A;for(const r of e)if("string"!=typeof r||r.includes(".")){const e=n(r);for(let n=0,r=t;n<e.length&&null!=r&&"object"==typeof r;++n)r=k(r,e[n],n!==e.length-1)}else k(t,r,!1)})),r.flags&=~e.ExplicitlyTracking)}function k(t,n,e){const o="?"===n[n.length-1]?n.slice(0,-1):n;if(null!=t.getItemAt||Array.isArray(t)){const n=parseInt(o,10);if(!isNaN(n))return Array.isArray(t)?t[n]:t.getItemAt(n)}const i=r(t)?.properties.get(o);return i&&(l(i),y(t,i)),e?t[o]:void 0}export{y as initializeDependencyTracking,s as resetGlobalTarget,g as runTracked,p as runTrackedNoThrow,u as runUntracked,l as trackAccess,h as trackExplicitDependencies};
 @ ./node_modules/@arcgis/core/core/accessorSupport/decorators/subclass.js 5:119-164 5:1223-1224
 @ ./src/main.ts
Error: ./node_modules/@arcgis/core/core/accessorSupport/read.js 5:1482
Module parse failed: Unexpected token (5:1482)
> import{valueOf as e,exists as t}from"./get.js";import{getProperties as r}from"./utils.js";import{originSpecificReadPropertyDefinition as n,originSpecificPropertyDefinition as o}from"./extensions/serializableProperty.js";function s(e,r,n){if(!e||!e.read||!1===e.read.enabled||!e.read.source)return!1;const o=e.read.source;if("string"==typeof o){if(o===r)return!0;if(o.includes(".")&&0===o.indexOf(r)&&t(o,n))return!0}else for(const s of o){if(s===r)return!0;if(s.includes(".")&&0===s.indexOf(r)&&t(s,n))return!0}return!1}function i(e){return e&&(!e.read||!1!==e.read.enabled&&!e.read.source)}function a(e,t,r,o,a){let f=n(t[r],a);i(f)&&(e[r]=!0);for(const i of Object.getOwnPropertyNames(t))f=n(t[i],a),s(f,r,o)&&(e[i]=!0)}function f(e,t,r,n){const s=r.metadatas,i=o(s[t],"any",n),a=i&&i.default;if(void 0===a)return;const f="function"==typeof a?a.call(e,t,n):a;void 0!==f&&r.set(t,f)}const c={origin:"service"};function u(t,o,s=c){if(!o||"object"!=typeof o)return;const i=r(t),u=i.metadatas,d={};for(const e of Object.getOwnPropertyNames(o))a(d,u,e,o,s);i.setDefaultOrigin(s.origin);for(const r of Object.getOwnPropertyNames(d)){const a=n(u[r],s).read,f=a&&a.source;let c;c=f&&"string"==typeof f?e(o,f):o[r],a&&a.reader&&(c=a.reader.call(t,c,o,s)),void 0!==c&&i.set(r,c)}if(!s||!s.ignoreDefaults){i.setDefaultOrigin("defaults");for(const e of Object.getOwnPropertyNames(u))d[e]||f(t,e,i,s)}i.setDefaultOrigin("user")}function d(e,t,r,n=c){const o={...n,messages:[]};r(o),o.messages?.forEach((t=>{"warning"!==t.type||e.loaded?n&&n.messages&&n.messages.push(t):e.loadWarnings.push(t)}))}export{u as read,d as readLoadable};
 @ ./node_modules/@arcgis/core/core/JSONSupport.js 5:265-314 5:622-623
 @ ./node_modules/@arcgis/core/geometry/SpatialReference.js
 @ ./src/main.ts
Error: ./node_modules/@arcgis/core/core/accessorSupport/extensions/serializableProperty/reader.js 5:346
Module parse failed: Unexpected token (5:346)
> import t from"../../../Logger.js";import{setDeepValue as e}from"../../../object.js";import r from"../../../Warning.js";import{getOwnClassMetadata as n}from"../../metadata.js";import{isCollection as o}from"./type.js";const i=t.getLogger("esri.core.accessorSupport.extensions.serializableProperty.reader");function p(t,r,n){t&&(!n&&!r.read||r.read?.reader||!1===r.read?.enabled||l(t)&&e("read.reader",s(t),r))}function s(t){const e=t.ndimArray??0;if(e>1)return c(t);if(1===e)return a(t);if("type"in t&&d(t.type)){const e=t.type.prototype?.itemType?.Type,r=a("function"==typeof e?{type:e}:{types:e});return(e,n,o)=>{const i=r(e,n,o);return i?new t.type(i):i}}return u(t)}function u(t){return"type"in t?y(t.type):g(t.types)}function y(t){return t.prototype.read?(e,r,n)=>{if(null==e)return e;const o=typeof e;if("object"!==o)return void i.error(`Expected JSON value of type 'object' to deserialize type '${t.prototype.declaredClass}', but got '${o}'`);const p=new t;return p.read(e,n),p}:t.fromJSON}function f(t,e,r,n){return 0!==n&&Array.isArray(e)?e.map((e=>f(t,e,r,n-1))):t(e,void 0,r)}function c(t){const e=u(t),r=f.bind(null,e),n=t.ndimArray??0;return(t,e,o)=>{if(null==t)return t;t=r(t,o,n);let i=n,p=t;for(;i>0&&Array.isArray(p);)i--,p=p[0];if(void 0!==p)for(let r=0;r<i;r++)t=[t];return t}}function a(t){const e=u(t);return(t,r,n)=>{if(null==t)return t;if(Array.isArray(t)){const r=[];for(const o of t){const t=e(o,void 0,n);void 0!==t&&r.push(t)}return r}const o=e(t,void 0,n);return void 0!==o?[o]:void 0}}function d(t){if(!o(t))return!1;const e=t.prototype.itemType;return!(!e||!e.Type)&&("function"==typeof e.Type?m(e.Type):j(e.Type))}function l(t){return"types"in t?j(t.types):m(t.type)}function m(t){return!Array.isArray(t)&&(!!t&&t.prototype&&("read"in t.prototype||"fromJSON"in t||d(t)))}function j(t){for(const e in t.typeMap){if(!m(t.typeMap[e]))return!1}return!0}function g(t){let e=null;const n=t.errorContext??"type";return(o,p,s)=>{if(null==o)return o;const u=typeof o;if("object"!==u)return void i.error(`Expected JSON value of type 'object' to deserialize, but got '${u}'`);e||(e=v(t));const y=t.key;if("string"!=typeof y)return;const f=o[y],c=f?e[f]:t.defaultKeyValue?t.typeMap[t.defaultKeyValue]:void 0;if(!c){const t=`Type '${f||"unknown"}' is not supported`;return s&&s.messages&&o&&s.messages.push(new r(`${n}:unsupported`,t,{definition:o,context:s})),void i.error(t)}const a=new c;return a.read(o,s),a}}function v(t){const e={};for(const r in t.typeMap){const o=t.typeMap[r],i=n(o.prototype);if("function"==typeof t.key)continue;const p=i.properties[t.key];if(!p)continue;p.json?.type&&Array.isArray(p.json.type)&&1===p.json.type.length&&"string"==typeof p.json.type[0]&&(e[p.json.type[0]]=o);const s=p.json?.write;if(!s||!s.writer){e[r]=o;continue}const u=s.target,y="string"==typeof u?u:t.key,f={};s.writer(r,f,y),f[y]&&(e[f[y]]=o)}return e}export{p as create,s as createTypeReader};
 @ ./node_modules/@arcgis/core/core/accessorSupport/extensions/serializableProperty.js 5:109-167 5:621-622 5:721-722
 @ ./src/main.ts
Error: ./node_modules/@arcgis/core/core/accessorSupport/DefaultsStore.js 5:347
Module parse failed: Unexpected token (5:347)
> import{clone as i}from"../lang.js";import{OriginId as e}from"./PropertyOrigin.js";class s{constructor(){this._values=new Map,this.multipleOriginsSupported=!1}clone(e){const t=new s;return this._values.forEach(((s,r)=>{e&&e.has(r)||t.set(r,i(s.value),s.origin)})),t}get(i,e){e=this._normalizeOrigin(e);const s=this._values.get(i);return null==e||s?.origin===e?s?.value:void 0}originOf(i){return this._values.get(i)?.origin??e.USER}keys(i){i=this._normalizeOrigin(i);const e=[...this._values.keys()];return null==i?e:e.filter((e=>this._values.get(e)?.origin===i))}set(i,s,r){if((r=this._normalizeOrigin(r))===e.DEFAULTS){const e=this._values.get(i);if(e&&null!=e.origin&&e.origin>r)return}this._values.set(i,new t(s,r))}delete(i,e){null!=(e=this._normalizeOrigin(e))&&this._values.get(i)?.origin!==e||this._values.delete(i)}has(i,e){return null!=(e=this._normalizeOrigin(e))?this._values.get(i)?.origin===e:this._values.has(i)}forEach(i){this._values.forEach((({value:e},s)=>i(e,s)))}_normalizeOrigin(i){if(null!=i)return i===e.DEFAULTS?i:e.USER}}class t{constructor(i,e){this.value=i,this.origin=e}}export{s as DefaultsStore};
 @ ./node_modules/@arcgis/core/core/JSONSupport.js 5:115-182 5:591-592
 @ ./src/main.ts
Error: ./node_modules/@arcgis/core/core/accessorSupport/extensions/serializableProperty/writer.js 5:354
Module parse failed: Unexpected token (5:354)
> import r from"../../../Error.js";import e from"../../../Logger.js";import{setDeepValue as t}from"../../../object.js";import{isCollection as n}from"./type.js";const i=e.getLogger("esri.core.accessorSupport.extensions.serializableProperty.writer");function o(r,e){if(!e.write||e.write.writer||!1===e.write.enabled&&!e.write.overridePolicy)return;const t=r?.ndimArray??0;r&&(1===t||"type"in r&&n(r.type))?e.write.writer=c:t>1?e.write.writer=w(t):e.types?Array.isArray(e.types)?e.write.writer=f(e.types[0]):e.write.writer=s(e.types):e.write.writer=p}function s(r){return(e,t,n,i)=>e?u(e,r,i)?p(e,t,n,i):void 0:p(e,t,n,i)}function u(e,t,n){for(const r in t.typeMap)if(e instanceof t.typeMap[r])return!0;if(n?.messages){const o=t.errorContext??"type",s=`Values of type '${("function"!=typeof t.key?e[t.key]:e.declaredClass)??"Unknown"}' cannot be written`;n&&n.messages&&e&&n.messages.push(new r(`${o}:unsupported`,s,{definition:e,context:n})),i.error(s)}return!1}function f(r){return(e,t,n,i)=>{if(!e||!Array.isArray(e))return p(e,t,n,i);return p(e.filter((e=>u(e,r,i))),t,n,i)}}function p(r,e,n,i){t(n,y(r,i),e)}function y(r,e){return r&&"function"==typeof r.write?r.write({},e):r&&"function"==typeof r.toJSON?r.toJSON():"number"==typeof r?a(r):r}function a(r){return r===-1/0?-Number.MAX_VALUE:r===1/0?Number.MAX_VALUE:isNaN(r)?null:r}function c(r,e,n,i){let o;null===r?o=null:r&&"function"==typeof r.map?(o=r.map((r=>y(r,i))),"function"==typeof o.toArray&&(o=o.toArray())):o=[y(r,i)],t(n,o,e)}function l(r,e,t){return 0!==t&&Array.isArray(r)?r.map((r=>l(r,e,t-1))):y(r,e)}function w(r){return(e,n,i,o)=>{let s;if(null===e)s=null;else{s=l(e,o,r);let t=r,n=s;for(;t>0&&Array.isArray(n);)t--,n=n[0];if(void 0!==n)for(let r=0;r<t;r++)s=[s]}t(i,s,n)}}export{o as create,a as numberToJSON};
 @ ./node_modules/@arcgis/core/core/accessorSupport/extensions/serializableProperty.js 5:230-288 5:714-715 5:736-737
 @ ./src/main.ts
Error: ./node_modules/@arcgis/core/core/accessorSupport/write.js 5:430
Module parse failed: Unexpected token (5:430)
> import{equals as r}from"../arrayUtils.js";import e from"../Error.js";import t from"../Logger.js";import{idToReadableName as i,OriginId as o,nameToId as n}from"./PropertyOrigin.js";import{getProperties as s,merge as u}from"./utils.js";import{originSpecificWritePropertyDefinition as l}from"./extensions/serializableProperty.js";const a=t.getLogger("esri.core.accessorSupport.write");function f(r,e,t,i,o){const n={};return e.write?.writer?.call(r,i,n,t,o),n}function p(r,t,i,s,u,l){if(!s||!s.write)return!1;const f=r.get(i);if(!u&&s.write.overridePolicy){const e=s.write.overridePolicy.call(r,f,i,l);void 0!==e&&(u=e)}if(u||(u=s.write),!u||!1===u.enabled)return!1;if((null===f&&!u.allowNull&&!u.writerEnsuresNonNull||void 0===f)&&u.isRequired){const t=new e("web-document-write:property-required",`Missing value for required property '${i}' on '${r.declaredClass}'`,{propertyName:i,target:r});return t&&l&&l.messages?l.messages.push(t):t&&!l&&a.error(t.name,t.message),!1}if(void 0===f)return!1;if(null===f&&!u.allowNull&&!u.writerEnsuresNonNull)return!1;if((!t.store.multipleOriginsSupported||t.store.originOf(i)===o.DEFAULTS)&&c(r,i,l,s,f))return!1;if(!u.ignoreOrigin&&l&&l.origin&&t.store.multipleOriginsSupported){if(t.store.originOf(i)<n(l.origin))return!1}return!0}function c(e,t,i,o,n){const s=o.default;if(void 0===s)return!1;if(null!=o.defaultEquals)return o.defaultEquals(n);if("function"==typeof s){if(Array.isArray(n)){const o=s.call(e,t,i);return r(o,n)}return!1}return s===n}function g(r,e,t,i){const o=s(r),n=o.metadatas,u=l(n[e],i);return!!u&&p(r,o,e,u,t,i)}function d(r,e,t){if(r&&"function"==typeof r.toJSON&&(!r.toJSON.isDefaultToJSON||!r.write))return u(e,r.toJSON(t));const o=s(r),n=o.metadatas;for(const s in n){const a=l(n[s],t);if(!p(r,o,s,a,void 0,t))continue;const c=r.get(s),g=f(r,a,a.write&&"string"==typeof a.write.target?a.write.target:s,c,t);Object.keys(g).length>0&&(e=u(e,g),t?.resources?.pendingOperations?.length&&Promise.all(t.resources.pendingOperations).then((()=>u(e,g))),t&&t.writtenProperties&&t.writtenProperties.push({target:r,propName:s,oldOrigin:i(o.store.originOf(s)),newOrigin:t.origin}))}return e}export{g as willPropertyWrite,d as write};
 @ ./node_modules/@arcgis/core/core/JSONSupport.js 5:373-424 5:655-656
 @ ./src/main.ts
Error: ./node_modules/@arcgis/core/core/unitUtils.js 5:6384
Module parse failed: Unexpected token (5:6384)
> import"./has.js";import{strict as e}from"./jsonMap.js";import{unwrapOr as s,isSome as t,isNone as r}from"./maybe.js";import{getReferenceEllipsoid as i}from"../geometry/projectionEllipsoid.js";import n from"../geometry/SpatialReference.js";import{earth as a,mars as u,moon as c}from"../geometry/support/Ellipsoid.js";import{isEarth as o,isWKIDFromMars as l,isWKIDFromMoon as m}from"../geometry/support/spatialReferenceUtils.js";import f from"../geometry/support/WKIDUnitConversion.js";const d=39.37,U=a.radius*Math.PI/200,q=/UNIT\[([^\]]+)\]\]$/i,p=f,h=/UNIT\[([^\]]+)\]/i,B=new Set([4261,4305,4807,4810,4811,4812,4816,4819,4821,4901,4902,37225,104139,104140]),b=e()({meter:"meters",foot:"feet",foot_us:"us-feet",foot_clarke:"clarke-feet",yard_clarke:"clarke-yards",link_clarke:"clarke-links",yard_sears:"sears-yards",foot_sears:"sears-feet",chain_sears:"sears-chains",chain_benoit_1895_b:"benoit-1895-b-chains",yard_indian:"indian-yards",yard_indian_1937:"indian-1937-yards",foot_gold_coast:"gold-coast-feet",chain_sears_1922_truncated:"sears-1922-truncated-chains","50_kilometers":"50-kilometers","150_kilometers":"150-kilometers"}),k=e=>e*e,y=e=>e*e*e,g={length:{baseUnit:"meters",units:{millimeters:{inBaseUnits:.001},centimeters:{inBaseUnits:.01},decimeters:{inBaseUnits:.1},meters:{inBaseUnits:1},kilometers:{inBaseUnits:1e3},inches:{inBaseUnits:.0254},feet:{inBaseUnits:.3048},yards:{inBaseUnits:.9144},miles:{inBaseUnits:1609.344},"nautical-miles":{inBaseUnits:1852},"us-feet":{inBaseUnits:1200/3937}}},area:{baseUnit:"square-meters",units:{"square-millimeters":{inBaseUnits:k(.001)},"square-centimeters":{inBaseUnits:k(.01)},"square-decimeters":{inBaseUnits:k(.1)},"square-meters":{inBaseUnits:1},"square-kilometers":{inBaseUnits:k(1e3)},"square-inches":{inBaseUnits:k(.0254)},"square-feet":{inBaseUnits:k(.3048)},"square-yards":{inBaseUnits:k(.9144)},"square-miles":{inBaseUnits:k(1609.344)},"square-us-feet":{inBaseUnits:k(1200/3937)},acres:{inBaseUnits:.0015625*k(1609.344)},ares:{inBaseUnits:100},hectares:{inBaseUnits:1e4}}},volume:{baseUnit:"liters",units:{liters:{inBaseUnits:1},"cubic-millimeters":{inBaseUnits:1e3*y(.001)},"cubic-centimeters":{inBaseUnits:1e3*y(.01)},"cubic-decimeters":{inBaseUnits:1e3*y(.1)},"cubic-meters":{inBaseUnits:1e3},"cubic-kilometers":{inBaseUnits:1e3*y(1e3)},"cubic-inches":{inBaseUnits:1e3*y(.0254)},"cubic-feet":{inBaseUnits:1e3*y(.3048)},"cubic-yards":{inBaseUnits:1e3*y(.9144)},"cubic-miles":{inBaseUnits:1e3*y(1609.344)}}},angle:{baseUnit:"radians",units:{radians:{inBaseUnits:1},degrees:{inBaseUnits:Math.PI/180}}}},_=(()=>{const e={};for(const s in g)for(const t in g[s].units)e[t]=s;return e})();function M(e,s,t){return e*g[t].units[s].inBaseUnits}function w(e,s,t){return e/g[t].units[s].inBaseUnits}const S=["metric","imperial","square-inches","square-feet","square-yards","square-miles","square-us-feet","square-meters","square-kilometers","acres","ares","hectares"],j=["metric","imperial","inches","feet","yards","miles","nautical-miles","us-feet","meters","kilometers"],I=new Map([["meters","square-meters"],["feet","square-feet"],["us-feet","square-us-feet"]]);function P(e){return"imperial"===e||"metric"===e}function C(e){const s=_[e];if(!s)throw new Error("unknown type");return s}function D(e){return g[e].baseUnit}function x(e){return D(C(e))}function E(e,s=null){return s=s||C(e),g[s].baseUnit===e}function N(e,s,t){if(s===t)return e;const r=C(s);if(r!==C(t))throw new Error("incompatible units");const i=E(s,r)?e:M(e,s,r);return E(t,r)?i:w(i,t,r)}function v(e,s,t){switch(t){case"metric":return R(e,s);case"imperial":return K(e,s);default:return t}}function F(e,s,t){switch(t){case"metric":return J(e,s);case"imperial":return A(e,s);default:return t}}function O(e,s,t){switch(t){case"metric":return T(e,s);case"imperial":return Y(e,s);default:return t}}function R(e,s){const t=N(e,s,"meters");return Math.abs(t)<3e3?"meters":"kilometers"}function J(e,s){const t=N(e,s,"meters");return Math.abs(t)<1e5?"meters":"kilometers"}function K(e,s){const t=N(e,s,"feet");return Math.abs(t)<1e3?"feet":"miles"}function A(e,s){const t=N(e,s,"feet");return Math.abs(t)<1e5?"feet":"miles"}function T(e,s){const t=N(e,s,"square-meters");return Math.abs(t)<3e6?"square-meters":"square-kilometers"}function Y(e,s){const t=N(e,s,"square-feet");return Math.abs(t)<1e6?"square-feet":"square-miles"}function G(e,s,t){return N(e,s,"meters")/(t*Math.PI/180)}function H(e){return b.fromJSON(e.toLowerCase())||null}function L(e){return b.toJSON(e)||null}function W(e){if(e&&"object"==typeof e&&!o(e))return 1;const s=z(e);return s>1e5?1:s}function $(e){return z(e)>=(e instanceof n?i(e).metersPerDegree:1e5)?"meters":Z(e)}function z(e,t=a.metersPerDegree){return s(Q(e,!0),t)}function Q(e,s=!1){let t,r,i=null;if(null!=e&&("object"==typeof e?(t=e.wkid,r=e.wkt):"number"==typeof e?t=e:"string"==typeof e&&(r=e)),t){if(l(t))return u.metersPerDegree;if(m(t))return c.metersPerDegree;i=p.values[p[t]],!i&&s&&B.has(t)&&(i=U)}else r&&(ie(r)?i=V(q.exec(r),i):re(r)&&(i=V(h.exec(r),i)));return i}function V(e,s){return e&&e[1]?X(e[1]):s}function X(e){return parseFloat(e.split(",")[1])}function Z(e){let s,r,i=null;if(null!=e&&("object"==typeof e?(s=e.wkid,r=e.wkt):"number"==typeof e?s=e:"string"==typeof e&&(r=e)),s)i=p.units[p[s]];else if(r){const e=ie(r)?q:re(r)?h:null;if(e){const s=e.exec(r);s&&s[1]&&(i=ae(s[1]))}}return t(i)?H(i):null}function ee(e){const s=Z(e);return r(s)||!j.includes(s)?null:s}function se(e){const s=$(e);return r(s)||!j.includes(s)?null:s}function te(e){const s=Z(e);return r(s)?null:I.get(s)}function re(e){return/^GEOCCS/i.test(e)}function ie(e){return/^PROJCS/i.test(e)}const ne=1e-7;function ae(e){const s=/[\\"\\']{1}([^\\"\\']+)/.exec(e);let t=s&&s[1];if(!t||!p.units.includes(t)){const s=X(e);t=null;const r=p.values;for(let e=0;e<r.length;++e)if(Math.abs(s-r[e])<ne){t=p.units[e];break}}return t}function ue(e){const s=Z(e);if(r(s))return null;switch(s){case"feet":case"us-feet":case"clarke-feet":case"clarke-yards":case"clarke-links":case"sears-yards":case"sears-feet":case"sears-chains":case"benoit-1895-b-chains":case"indian-yards":case"indian-1937-yards":case"gold-coast-feet":case"sears-1922-truncated-chains":return"imperial";case"50-kilometers":case"150-kilometers":case"meters":return"metric"}return null}function ce(e){const t="metric";if(r(e))return t;const i=e.map,n=i&&"portalItem"in i?i.portalItem?.portal:null;if(n){switch(n?.user?.units??n.units){case t:return t;case"english":return"imperial"}}return s(ue(e.spatialReference),t)}const oe={esriAcres:"acres",esriAres:"ares",esriHectares:"hectares",esriSquareCentimeters:"square-centimeters",esriSquareDecimeters:"square-decimeters",esriSquareFeet:"square-feet",esriSquareInches:"square-inches",esriSquareKilometers:"square-kilometers",esriSquareMeters:"square-meters",esriSquareMiles:"square-miles",esriSquareMillimeters:"square-millimeters",esriSquareUsFeet:"square-us-feet",esriSquareYards:"square-yards"},le={esriCentimeters:"centimeters",esriDecimeters:"decimeters",esriFeet:"feet",esriInches:"inches",esriKilometers:"kilometers",esriMeters:"meters",esriMiles:"miles",esriMillimeters:"millimeters",esriNauticalMiles:"nautical-miles",esriYards:"yards"},me=e()(oe),fe=e()(le),de=e()({...oe,...le});export{te as areaUnitFromSpatialReference,me as areaUnitsJSONMap,x as baseUnitForUnit,D as baseUnitForUnitType,N as convertUnit,ce as getDefaultUnitForView,ue as getDefaultUnitSystem,Q as getMetersPerUnit,z as getMetersPerUnitForSR,W as getMetersPerVerticalUnitForSR,Z as getUnitString,$ as getVerticalUnitStringForSR,d as inchesPerMeter,E as isBaseUnit,P as isMeasurementSystem,G as lengthToDegrees,ee as lengthUnitFromSpatialReference,fe as lengthUnitsJSONMap,S as measurementAreaUnits,j as measurementLengthUnits,O as preferredAreaUnit,Y as preferredImperialAreaUnit,K as preferredImperialLengthUnit,A as preferredImperialVerticalLengthUnit,v as preferredLengthUnit,T as preferredMetricAreaUnit,R as preferredMetricLengthUnit,J as preferredMetricVerticalLengthUnit,F as preferredVerticalLengthUnit,H as unitFromRESTJSON,L as unitToRESTJSON,C as unitType,de as unitsJSONMap,se as verticalLengthUnitFromSpatialReference};
 @ ./node_modules/@arcgis/core/geometry/support/geodesicUtils.js 5:61-115 5:1851-1852 5:2508-2509 5:5961-5962
 @ ./src/main.ts
Error: ./node_modules/@arcgis/core/geometry/support/offset.js 5:66
Module parse failed: Unexpected token (5:66)
> function n(n,r,t,u){return n.x=n.x+r,n.y=n.y+t,null!=u&&(n.z=(n.z??0)+u),n}function r(n,r){return n[0]+=r,n}export{r as offsetCoordsX,n as offsetPoint};
 @ ./node_modules/@arcgis/core/geometry/Point.js 5:660-710 5:3817-3818
 @ ./src/main.ts
Error: ./node_modules/@arcgis/core/core/Accessor.js 5:722
Module parse failed: Unexpected token (5:722)
> import{isIterable as t}from"./iteratorUtils.js";import{applySome as r,isNone as e}from"./maybe.js";import{get as s}from"./accessorSupport/get.js";import{Lifecycle as o}from"./accessorSupport/interfaces.js";import{getOwnClassMetadata as i}from"./accessorSupport/metadata.js";import c from"./accessorSupport/Properties.js";import{set as n}from"./accessorSupport/set.js";import{removeTarget as a,watch as _}from"./accessorSupport/watch.js";import{property as u}from"./accessorSupport/decorators/property.js";import{subclass as h}from"./accessorSupport/decorators/subclass.js";var p;function l(t){if(null==t)return{value:t};if(Array.isArray(t))return{type:[t[0]],value:null};switch(typeof t){case"object":return t.constructor?.__accessorMetadata__||t instanceof Date?{type:t.constructor,value:t}:t;case"boolean":return{type:Boolean,value:t};case"string":return{type:String,value:t};case"number":return{type:Number,value:t};case"function":return{type:t,value:null};default:return}}const d=Symbol("Accessor-Handles");class y{constructor(...t){if(this[p]=null,this.constructor===y)throw new Error("[accessor] cannot instantiate Accessor. This can be fixed by creating a subclass of Accessor");Object.defineProperty(this,"__accessor__",{enumerable:!1,value:new c(this)}),t.length>0&&this.normalizeCtorArgs&&(this.__accessor__.ctorArgs=this.normalizeCtorArgs.apply(this,t))}static createSubclass(t={}){if(Array.isArray(t))throw new Error("Multi-inheritance unsupported since 4.16");const{properties:r,declaredClass:e,constructor:s}=t;delete t.declaredClass,delete t.properties,delete t.constructor;const o=this;class c extends o{constructor(...t){super(...t),this.inherited=null,s&&s.apply(this,t)}}i(c.prototype);for(const i in t){const r=t[i];c.prototype[i]="function"==typeof r?function(...t){const e=this.inherited;let s;this.inherited=function(...t){if(o.prototype[i])return o.prototype[i].apply(this,t)};try{s=r.apply(this,t)}catch(c){throw this.inherited=e,c}return this.inherited=e,s}:t[i]}for(const i in r){const t=l(r[i]);u(t)(c.prototype,i)}return h(e)(c)}postscript(t){const r=this.__accessor__,e=r.ctorArgs||t;r.initialize(),e&&(this.set(e),r.ctorArgs=null),r.constructed(),this.initialize()}initialize(){}destroy(){this.destroyed||(r(this[d],(t=>{t.forEach((t=>t.remove()))})),this[d]=null,a(this),this.__accessor__.destroy())}get initialized(){return this.__accessor__&&this.__accessor__.initialized||!1}get constructed(){return this.__accessor__&&this.__accessor__.lifecycle===o.CONSTRUCTED||!1}get destroyed(){return this.__accessor__&&this.__accessor__.destroyed||!1}commitProperty(t){this.get(t)}get(t){return s(this,t)}hasOwnProperty(t){return this.__accessor__?this.__accessor__.has(t):Object.prototype.hasOwnProperty.call(this,t)}keys(){return this.__accessor__?this.__accessor__.keys():[]}set(t,r){return n(this,t,r),this}watch(t,r,e){return _(this,t,r,e)}own(r){let s=this[d];if(e(s)&&(s=this[d]=new Set),t(r))for(const t of r)s.add(t);else s.add(r)}_clearOverride(t){return this.__accessor__.clearOverride(t)}_override(t,r){return this.__accessor__.override(t,r)}_isOverridden(t){return this.__accessor__.isOverridden(t)}notifyChange(t){this.__accessor__.notifyChange(t)}_get(t){return this.__accessor__.internalGet(t)}_set(t,r){return this.__accessor__.internalSet(t,r),this}}p=d;export{y as default};
 @ ./node_modules/@arcgis/core/core/JSONSupport.js 5:43-72 5:1058-1059
 @ ./src/main.ts
Tags (3)
jauhari_mani
Hi @AndyGup ,
After reviewing your Git repository, I noticed that it contained a starter sample for Angular 11 using ArcGIS 4.19. However, I would like to make use of the @arcgis/core version 4.26 in Angular @9.0.0. Could you please guide me on how to achieve this and provide any necessary configuration steps?
AndyGup
@jauhari_manihere is the link to the repo for ArcGIS JS SDK's ESM samples: https://github.com/Esri/jsapi-resources/tree/main/esm-samples and there is an Angular v15 (soon to be upgraded to v16) sample in there. We provide these unsupported samples as proof-of-concepts for the latest shipping version the ArcGIS JS SDK (4.26) plus the latest version of framework or bundler.
Note, Angular 9 is no longer supported by Google: https://angular.io/guide/releases#actively-supported-versions.
If you run into issues with client-side build tools, we also have this handy troubleshooting guide: https://github.com/Esri/jsapi-resources/blob/main/TROUBLESHOOTING.md
For framework or bundler questions, it's best to contact those communities directly.
Stacy-Rendall
I had a similar issue caused by an optional chaining operator that appeared in the codebase of ArcGIS API 4.24. Some build tools (Vue 2.7 project, so Webpack 4) don't support that.
Fix from here: https://github.com/vuejs/vue-loader/issues/1697#issuecomment-997157081, basically add the following to your vue.config.js:
  chainWebpack: config => {
    // @arcgis/core uses optional chaining, which isn't supported by default
    config.module
      .rule('@arcgis/core')
      .test({
        test: /\.js$/,
        include: path.join(__dirname, 'node_modules/@arcgis/core')
      .use('babel-loader')
      .loader('babel-loader')
      .options({
        presets: ['@babel/preset-env'],
        plugins: ['@babel/plugin-proposal-optional-chaining']
      .end()
AndyGup
Thanks for posting that info @Stacy-Rendall. With respect to the original posting on this thread, there are issues with Webpack 4 and "@arcgis/core" versions 4.24+ due to the API being upgraded to ES2020 and including both optional chaining and nullish coalescing operators. Here's the full explanation and Webpack configuration recommendations: https://github.com/Esri/jsapi-resources/tree/master/esm-samples/webpack#known-issues
