Bug on js map ver 4.1
6376
18
12-09-2016 02:56 AM
LaxmanThapa
When map isnot placed at the top of the page, the map has following bugs
  • The zoom on mouse wheel is not centered
  • The popup on map click does not position correctly.
If I place the same map on the top of the page, then I do not have this bug.
Can someone help us solve this problem. Please click on the JSFiddle to see the bug.
Edit fiddle - JSFiddle
Tags (1)
ReneRubalcava
Esri Frequent Contributor
What browser are you using? I'm not seeing any issue with popups or zoom using the latest fiddles you provided in Chrome, Firefox or Safari.
RickeyFight
I see the issue with Chrome.
KenBuja
MVP Esteemed Contributor
I'm seeing it in Firefox, Chrome, and IE
ReneRubalcava
Checked on a smaller screen, happens when you scroll down. I'll pass it on.
KenBuja
This seems to be the same issue that happens in 3.x and was solved using map.reposition(). That option isn't available for the MapView, however.
ReneRubalcava
This will be fixed in 4.2.
LaxmanThapa
Do you know when version 4.2 will be released because I have to put online my website this week and this map is critical?
ReneRubalcava
Should be out this week.
LaxmanThapa
Thank to the updates on the new release i.e. 4.2, the bug has been fixed.
Laxman
