Buffer problem
1176
06-30-2014 02:55 AM
RyanSmith1
Hi, i have the following piece of code to perform a buffer operation after an onclick event on a button component, but for some reason the Buffer only gets produced after the second click.
 function doBuffer(geometryToBuffer)
  var params = new esri.tasks.BufferParameters();
  params.geometries = [geometryToBuffer];
  params.distances = [5,15];
  params.unit = esri.tasks.GeometryService.UNIT_KILOMETER;
  params.outSpatialReference = map.spatialReference;
  gsvc.buffer(params, showBuffer);
   function showBuffer(geometries)
        var symbol = new esri.symbol.SimpleFillSymbol(
          esri.symbol.SimpleFillSymbol.STYLE_SOLID,
          new esri.symbol.SimpleLineSymbol(
            esri.symbol.SimpleLineSymbol.STYLE_SOLID,
            new dojo.Color([0, 0, 255, 0.65]), 2
          new dojo.Color([0, 0, 255, 0.35])
        dojo.forEach(geometries, function (geometry) {
            var graphic = new esri.Graphic(geometry, symbol);
            map.graphics.add(graphic);
AlexeiB
Does the doBuffer(..) function get called on the first click?
RyanSmith1
Thanks for the reply Alex, Yes it does get called on the first click
JeffPace
on first click, is geometryToBuffer valid or is it null
