Bower Error
3500
03-07-2016 09:49 AM
by Anonymous User
Not applicable
Hello -
I am trying to download a local copy of v3.16 of the JavaScript API. I used to use Slurp and it took me a while to grasp Grunt and all of the configuration files. I thought with Bower I could run one command and have the minified files. But when I try to run 'bower install --save arcgis-js-api' from the command line I get the following error:
bower    ECONFLICT Unable to find suitable version for dojo
I have no idea how to deal with that.
Tags (1)
ReneRubalcava
Esri Frequent Contributor
That should give you a dialog similar to this.
Unable to find a suitable version for dojo, please choose one:
    1) dojo#v1.10.4/esri-3.14.0 which resolved to v1.10.4/esri-3.14.0 and is required by arcgis-js-api#3.16.0
    2) dojo#>=1.8.1 which resolved to 1.10.4 and is required by dstore#1.1.0
Prefix the choice with ! to persist it to bower.json
? Answer
Enter "!1" and it will save your choice in the bower.json file.
You could set up a bower.json ahead of time like the one here.
https://github.com/Esri/jsapi-resources/blob/master/bower/dojo/bower.json
That could help.
Thanks!
by Anonymous User
Not applicable
I just re-ran it to see the error again and try your suggestion, and it ran fine...so I don't know what I did before!
JasonBaker4
I have the same problem. "bower    ECONFLICT Unable to find suitable version for dojo"
I don't see an option to select a dojo version. The ECONFLICT is the last line before going back to command prompt $. I'm using gitbash on windows.
