BasemapGallery how to set source from my URL
1820
08-24-2022 11:59 AM
DimaY
How can I set the objects I want from my url to BasemapGallery  and not those that are in it initially from default?
Project Angular ASP NET6. I am using the object  const world = new WMSLayer({ url: "my Url "});
const map = new Map({
ground: "world-elevation",
layers: [world]
const container = this.mapViewEl.nativeElement;
const view = new MapView({
container,
map: map
const basemapGallery = new BasemapGallery({
view: view
view.ui.add(basemapGallery, "top-right"); // Add to the view
How to set new my source to BasemapGallery?
Thanks!
AnneFitz
Hi, you can add your own basemaps via the source property of the BasemapGallery. Something like this:
// create a basemap with your WMS layer as the base layer
const worldBasemap = new Basemap({
  baseLayers: [world]
   view: view,
   // set the source to an array of basemaps
   //   here we are including the worldBasemap from your WMSLayer
   //   and the Esri hybrid basemap
   source: [worldBasemap, Basemap.fromId("hybrid")]
DimaY
First of all, thank you very much for your reply!
Please tell me what is in your code view? I had a MapView with that view name. What do you have?
In your code Basemap.fromId("hybrid") where did you define it - Basemap? Why am I asking? Because you defined this const worldBasemap = new Basemap({
baseLayers: [world]
As a programmer, I got the idea that I should define a new Basemap object in which I should insert and define property baseLayers , which in turn, I will take from WMSLayer, in which, in turn, I will insert my URL. Something like that, yes?
And thank you very much, you helped me a lot!
AnneFitz
I was using a MapView. But either MapView or SceneView should work.
This is an API class "esri/Basemap" that I imported at the name time as my MapView and BasemapGallery: https://developers.arcgis.com/javascript/latest/api-reference/esri-Basemap.html
Yes, that sounds about right!
DimaY
Here is an example of my code and it doesn't work, what is done wrong? Thank you!
import {
Component,
OnInit,
ViewChild,
ElementRef,
OnDestroy,
} from '@angular/core';
import Map from '@arcgis/core/Map';
import Basemap from "@arcgis/core/Basemap";;
import SceneView from '@arcgis/core/views/SceneView';
import WMSLayer from '@arcgis/core/layers/WMSLayer';
import BasemapGallery from "@arcgis/core/widgets/BasemapGallery";
@Component({
selector: 'app-root',
templateUrl: './app.component.html',
styleUrls: ['./app.component.css'],
export class AppComponent implements OnInit, OnDestroy {
public view: any = null;
// The <div> where we will place the map
@ViewChild('mapViewNode', { static: true }) private mapViewEl!: ElementRef;
initializeMap(): Promise<any> {
url: "example my geoserver url",
layers: [world]
const view = new SceneView({
container,
map: map
baseLayers: [world]
view: view,
source: [worldBasemap]
this.view = view;
return this.view.when();
ngOnInit(): any {
this.initializeMap().then(() => {
console.log('The map is ready.');
ngOnDestroy(): void {
if (this.view) {
this.view.destroy();
