Barriers in Multimodal Network Dataset ArcGIS API WAB
1544
02-26-2018 07:43 AM
AlbertoLópez
I'm developing an application with WAB and the JS 3.22 API to calculate routes over a multimodal networks dataset.
When I add barriers I find that several lines of network 1 of the network dataset (subway for example) has the  same geometry that several lines in  network 2 (bus for example). And when I add barriers in the coordinates of the lines with the same geometry, the barrier applies to both networks (subway and bus),  and I need that the barrieres applies only to one network.
I am adding the barriers in this way:
                     var polylineJson = {
                            "paths":[[[x1, y1], [x2, y2]
                            "spatialReference":{"wkid":this.config.spatialReference}
                        var polyline = new Polyline(polylineJson);
                        var myGraphic = new Graphic(polyline, null);
myGraphic.setAttributes(…);
                        routeParams.polylineBarriers.features.push(myGraphic);
But I do not know how to indicate that the barrier affects only the network that I want.
I don`t know if I have to change  my  JS  code or the Network Dataset
 Does this problem have a solution?
Thanks, greetings.
RobertScheitlin__GISP
Alberto,
   Do both networks (subways and bus) use the same routeTask URL?
AlbertoLópez
Yes.
Thanks.
I am not aware of a way to apply barriers to a specific subset of the Geometry network.
