autocomplete working with geocoder
3862
06-20-2013 06:26 AM
Asta_KristinOladottir
I am not able to get autocomplete to work, It works fine when I build an application with ArcGIS viewer for flex but when I build an application with the same geocode service with arcgis api for javascript (https://gis.lmi.is/ako_os/) it doesn't work.
Here is my code:
var myGeocoders = [{
             url: locatorUrl,
      singleLineFieldName: "SingleLineCityName"
        var geocoder = new esri.dijit.Geocoder({
          map: map,
          autocomplete: true,
          arcgisGeocoder: false,
          geocoders: myGeocoders
        },"search");
        geocoder.startup();
[ATTACH=CONFIG]25383[/ATTACH]
KellyHutchins
Esri Notable Contributor
I ran a quick test using your geocoder and autocomplete worked for me. Here's a fiddle showing the working code:
http://jsfiddle.net/uTW6e/
KellyHutchins
Thank you very much Kelly 🙂
