assign values to evt parameters
1388
03-24-2013 06:27 PM
deleted-user-ATjHIWsdQYmT
I am trying to programatically execute an "identify" by passing x/y coords.  I have been able to pass the mapPoint but cannot get the syntax right to include the screenPoint.  Here is the code I'm using:
doIdentify({
"mapPoint": thisPoint
Can anyone point me in the right direction on how to add the screenPoint as well?
Thanks.
Thanks John.  I ended up figuring it out.  My issues I was encountering were more syntax related.  That was my biggest problem.
For those looking to pass values to an identify function via code as opposed to a map click, here's my working code:
dojo.forEach(lblPoint, function(labelPoint){
                      pt = labelPoint;
                      pickIdentify({
                          "mapPoint": pt,
                          "screenPoint": map.toScreen(pt)
JohnGravois
have you already seen map.toScreen()?
                      pt = labelPoint;
                      pickIdentify({
                          "mapPoint": pt,
