ArcGis Server Setup + proxy server + webadaptor
1110
09-12-2013 03:37 AM
vinayb
HI All,
  I am absolutely no knowledge on ArcGis server side, I have team who uses ArcGis with cog-nos plugin.
  I am using the same server i.e standalone server which runs in 6080 to consume for my web application.
  Now i came across issue where i have to set up proxy server , i discovered that proxy is not working properly.
DO i have to install web adapter if so which adapter ,my Dev machine runs in Linux.
JohnGravois
hi vinay. you do not have to install the web adaptor in order to work with a proxy.
