ArcGIS Server's Query - Returned w/ different records
1111
11-24-2014 09:26 AM
ShaningYu
Honored Contributor
I tried 2 things:
1)  Run the code sourced from ESRI (see attached).  The query returned > 100 features and populated on the left pane's Grid.
2)  Go to the service site: http://trainingcloud.arcgis.com/arcgis/rest/services/Redlands_PointsOfInterest/MapServer/0, and run the query:   where:  NAME Like '%Redlands%'   Geometry Type:  Envelope   Out fields:  OBJECTID, NAME, Match_addr, TEL, TYPE   Spatialo relationship: Contains Or use the link  http://trainingcloud.arcgis.com/arcgis/rest/services/Redlands_PointsOfInterest/MapServer/0/query?whe... which results in only 12 records.
Tried several times with the same results on both cases.  Can someone explain why?  Thanks.
My Template
NameAddress
Created by J. Doe
RobertScheitlin__GISP
Shaning,
    no it was not attached when I replied.
The issue is initially when you run the code the results contain all features that intersect the maps view extent and when you run your query you are only looking for features that have 'Redlands' in its name.
I think your confusion is that you are seeing 'Redlands' in the in the Match_addr of the initial 100+ results and are expecting to see the same when you query.  If you change your query to  this then you will see results similar to what you are when you initially run the app:
Shaning
What code?
ShaningYu
Honored Contributor
Did you see the attached file? Thanks.
Shaning,
ShaningYu
Honored Contributor
Rob:  Thanks a lot.
