ArcGIS Maps SDK for Javascript 4.x - disable console error messages
3581
08-09-2023 06:01 AM
BhavinSanghani
How can we disable following types of error messages displayed on the browser console under Developer Tools? Is there any flag with 4.x API?
init.js:203 Uncaught (in promise) q {name: 'identity-manager:user-aborted', details: undefined, message: 'ABORTED'}
2 Solutions
AndrewMurdoch1
Good Day
This is how I disable the console messages.  This allows you to turn off different message types, so in production you can disable all logging, which is generally a good idea.
const disableErr: boolean = false;
const disableLog: boolean = false;
const disableTime: boolean = true;
if (window && disableLog) {
  window.console.log = () => {
  window.console.table = () => {
  window.console.info = () => {
if (window) {
  if (disableErr) {
    window.console.error = () => {
  if (disableTime) {
    window.console.time = () => {
    window.console.timeLog = () => {
    window.console.timeEnd = () => {
Cheers
BhavinSanghani
Looks like Andrew has given alternative way to achieve it. Thanks @AndrewMurdoch1 and @JoelBennett !
However, I found esri/config has log level and that can be useful.
JoelBennett
MVP Regular Contributor
You can use the filtering tools in your Developer Tools console to hide any unwanted messages, as described here and here.  For example, I prefer not to be inundated with error messages about missing tiles, so I usually have the filter:
-blankTile=false -esri.views.2d.layers.TileLayerView2D
In your case, perhaps you could have:
-identity-manager:user-aborted
BhavinSanghani
Thanks for replying @JoelBennett .
I just don't want to display these console messages coming from the API to our customers as they might be least concerned with that. I know they can be helpful for debugging. But it's better if the API has some flag value or logging level to set.
AndrewMurdoch1
Good Day
if (window) {
  if (disableErr) {
  if (disableTime) {
Cheers
JoelBennett
Ok, I see.  Unfortunately, the API has no such flag.  Attached is every use of "console" in the API, and you can see it is quite often used unconditionally.  Perhaps the best alternative is to override the console object's functions in a manner as mentioned by Andrew.
BhavinSanghani
