ArcGIS JS 4 Rotate Graphic
5469
13
04-26-2023 12:49 PM
BobCowling2
I am attempting to rotate an arrow based on a mobile phones device orientation. However simply changing the symbol angle does not seem to work. What is the proper way to rotate a graphic?
Thank you very much.
const arrowSymbol = {
  type: "simple-marker",
  path: "M10,0 L20,30 L10,20 L0,30 Z",
  color: [0, 0, 255, 1],
  outline: {
    color: [0, 0, 0, 1],
    width: 1
const arrowGraphic = new Graphic({
  symbol: arrowSymbol
const track = new Track({
  view: view,
  graphic: arrowGraphic,
  useHeadingEnabled: false
  // Add the Track widget to the view
  view.ui.add(track, "top-right");
  window.addEventListener("deviceorientation", (event) => {
  console.log(`${event.alpha} : ${event.beta} : ${event.gamma} : ${event.absolute} : ${event.webkitCompassHeading}`);
  // get the heading value from the device
  const heading = event.alpha ? event.alpha * -1 : 0;
  // Rotate the arrow symbol based on the device's heading.
  arrowGraphic.symbol.angle = heading;
Tags (1)
BobCowling2
Right, that makes sense. I am guessing I simply cannot rotate the track widget graphic, so the arrow should work as a separate graphic from the track widget one. Got it. Thanks for your help!
JoelBennett
MVP Regular Contributor
It's likely you'll have to replace the symbol object itself:
var newSymbol = arrowGraphic.symbol.clone();
newSymbol.angle = heading;
arrowGraphic.symbol = newSymbol;
If that doesn't work, you might try replacing the graphic entirely:
var newGraphic = arrowGraphic.clone();
newGraphic.symbol.angle = heading;
track.graphic = newGraphic;
BobCowling2
Thank you, Joel. I did try cloning the arrow but it was making a new arrow every time there was a new position. If this is the only way I will have to test more!
JamesIng
You'll need to manually remove the existing arrow graphic from the graphic layer first before adding the new one and that should prevent the visual stacking of arrows.
James from www.landkind.com
