Arcgis for server architecture using javascript API
5030
06-16-2015 11:09 AM
JavierPablos1
hello,
I have the following image (sorry it is in Spanish) representing the architecture of ArcGIS Server JavaScript API which is no longer correct since from ArcGIS for Server version 10.1 on, the SOM-SOC model is not implemented. Does anybody have an up-tp-date image representing the arquitecture currently use for ArcGIS for Server in order to make Web Apps using JS API??arquitectura.jpg
Thanks in advance.
Regards,
Javier
BjornSvensson
Esri Alum
Javier Pablos From a JavaScript API perspective, nothing has changed.  It still connects to the ArcGIS Server REST endpoints the same way as before.
JavierPablos1
Thanks a lot Bjorn for your reply. I know from the JavaScript API perspective nothing has changed. The SOM-SOC model in the GIS Server is what has changed. In addition a Web adaptor has been added. Therefore I am looking for a more up-to-date arquitecture diagram for the ArcGIS for server part.
Thanks agains.
Regards
KenBuja
MVP Esteemed Contributor
You may want to ask this question over in the ArcGIS for Server​ space to get those experts to help you out.
JavierPablos1
Thanks Ken
