arcgis core 4.23 breaks app when build
5575
9
04-08-2022 09:43 AM
FabianHanggi
Hello
Just upgraded from 4.22 to 4.23. When i run my app locally using npm start things work fine.
However when i build the app (npm run build) the maps don't load anymore. I see this error in the console
Uncaught (in promise) TypeError: _ is not a function
at e.value (RenderingContext.js:5:23779)
at e.value (RenderingContext.js:5:2866)
at new e (RenderingContext.js:5:1458)
at new i (Stage.js:5:2261)
at u.value (MapView.js:5:17175)
at u.<anonymous> (View.js:5:3490)
at watch.js:5:2481
at i (trackingUtils.js:5:281)
at p (trackingUtils.js:5:795)
at e.i [as _notify] (trackingUtils.js:5:288)
When i go back to 4.22 things work.
I'm using node v12.13.1 and npm 6.14.8
Does anyone else have these issues?
Thank you
Fabian
AndyGup
Hi @FabianHanggi sorry for the delay, this seems to be an issue with the browserslist. No clue why React uses those default params. I used the following settings and it built and ran on my machine:
  "browserslist": {
    "production": [
      "last 1 chrome version",
      "last 1 firefox version",
      "last 2 safari major versions",
      "last 2 edge major versions",
      "last 2 iOS major versions",
      "Firefox ESR"
    "development": [
      "Firefox ESR"    ]
AndyGup
@FabianHanggican you provide a github repository that reproduces the issue? If you don't want to share it publicly you can direct message me with a link.
Also, if you haven't had a chance yet, be sure to take a look at the 4.23 release notes in the breaking changes section: https://developers.arcgis.com/javascript/latest/release-notes/#breaking-changes.
FabianHanggi
Hi AndyGup
I attached a zip file where i was able to reproduce my issue .
Here is what you have to do.
unzip it into a folder
run npm install
run npm run build
deploy the app somewhere where you can run it on a server .i'm using IIS that's why there is a web.config file in my public folder with a rewrite rule. maybe you don't need that
when you run the app you should see a button. show map. click it. because the app is using 4.23.7 version you should just see a white screen. the map is not loaded.
edit package.json and change the version of arcgis to 4.22.2. run install and build again.
now the map loads.
note that i could not reproduce the  "TypeError: _ is not a function" as described in my original post. but i have a lot more code in my real app which i cannot reproduce in this sample
Let me know how it goes.
Thank you
Fabian
AndyGup
  "browserslist": {
    "production": [
      "Firefox ESR"
    "development": [
      "Firefox ESR"    ]
JackFairfield
I ran into this same issue in my CRA app.  Thanks for the browserslist fix above.  Do we think the issue is including IE11 basically?  And will this be fixed for 4.14?  Thanks
AndyGup
Hi@JackFairfield, this is a framework configuration issue, I didn't see any ArcGIS JS API bug.  It's common for the browserslist to be tweaked for performance and appropriate transpiling based on the system requirements of any dependencies. Note, we dropped IE 11 and Edge Legacy support back in December 2020 at 4.18 - more details here: https://developers.arcgis.com/javascript/latest/4.18/#end-of-ie11edge-legacy-support. Our latest System Requirements are described here: https://developers.arcgis.com/javascript/latest/system-requirements/
JackFanZhang
Thanks AndyGup, the broswerlist works!
DylanKennard
Hey @FabianHanggi - We have the same issue and the same error you posted. We rolled back and still it does not work. The Browserlist suggestion did not fix it either. Anything you ever found deep in the code that was trigger this?
The one thing I noticed is we are using node 16. We never deployed the app, so we never knew what it ever worked on. This is our first time deploying.
AndyGup
@DylanKennardnode 16 shouldn't be causing that error - on the surface it looks like a transpiler issue. If you can provide a simple github repo that reproduces the error we'll take a look.
FabianHanggi
Hi Dylan
Try to delete package-json and the node_modules folder. then run npm install again.
That fixed it for me together with the browserslist. I'm using node 16.4.2 and npm 8.5.0
Fabian
