@arcgis/core 4.19.3 + Angular 8 + TypeScript
3062
05-10-2021 08:09 PM
LeoDeng
Hi everybody,
   I'm trying to include ArcGIS JS API 4.19 in my Angular 8 project.
   The project was created by command "ng new esri-js-webmap" and it installed "arcgis/core" only by command "npm install @arcgis/core".
  After compile success, I got the console error "Uncaught ReferenceError: e is not defined" in the default site "localhost:4200".
It happens when "import EsriMap from "@arcgis/core/Map";" in src\app\esri-map\esri-map.component.ts
Here is the package.json dependencies:
  "dependencies": {
    "@angular/animations": "~8.0.0",
    "@angular/common": "~8.0.0",
    "@angular/compiler": "~8.0.0",
    "@angular/core": "~8.0.0",
    "@angular/forms": "~8.0.0",
    "@angular/platform-browser": "~8.0.0",
    "@angular/platform-browser-dynamic": "~8.0.0",
    "@angular/router": "~8.0.0",
    "@arcgis/core": "^4.19.3",
    "rxjs": "~6.4.0",
    "tslib": "^1.9.0",
    "zone.js": "~0.9.1"
And the tsconfig.json:
  "compileOnSave": false,
  "compilerOptions": {
    "declaration": true,
    "module": "commonjs",
    "moduleResolution": "node",
    "noEmitOnError": true,
    "noUnusedLocals": false,
    "noUnusedParameters": false,
    "noFallthroughCasesInSwitch": true,
    "outDir": "./dist",
    "rootDir": "./",
    "skipLibCheck": true,
    "strict": true,
    "target": "ES2019",
    "lib": ["ES2019"],
    "baseUrl": "",
    "rootDirs": ["src","out"],
    "typeRoots": ["./node_modules/@types"],
    "types": ["node"],
    "incremental": true,
    "tsBuildInfoFile": "./buildFile",
    "diagnostics": true,
    "strictNullChecks": false,
    "emitDecoratorMetadata": true,
    "experimentalDecorators": true,
  "angularCompilerOptions": {
    "fullTemplateTypeCheck": true,
    "strictInjectionParameters": true
Bests,
Leo
LeoDeng
After checking the document , I upgrade Angular to 11.2.13 and everything works fine.
Here is the dependencies and tsconfig
  "dependencies": {
    "@angular/animations": "~11.2.13",
    "@angular/common": "~11.2.13",
    "@angular/compiler": "~11.2.13",
    "@angular/core": "~11.2.13",
    "@angular/forms": "~11.2.13",
    "@angular/platform-browser": "~11.2.13",
    "@angular/platform-browser-dynamic": "~11.2.13",
    "@angular/router": "~11.2.13",
    "rxjs": "~6.6.0",
    "tslib": "^2.0.0",
    "zone.js": "~0.11.3"
/* To learn more about this file see: https://angular.io/config/tsconfig. */
    "baseUrl": "./",
    "outDir": "./dist/out-tsc",
    "forceConsistentCasingInFileNames": true,
    "strict": false,
    "noImplicitReturns": true,
    "sourceMap": true,
    "declaration": false,
    "downlevelIteration": true,
    "importHelpers": true,
    "target": "es2015",
    "module": "es2020",
    "lib": [
      "es2018",
      "dom"
    "enableI18nLegacyMessageIdFormat": false,
    "strictInjectionParameters": true,
    "strictInputAccessModifiers": true,
    "strictTemplates": true
Sorry for the confusion.
LeoDeng
  "dependencies": {
    "rxjs": "~6.6.0",
    "tslib": "^2.0.0",
    "baseUrl": "./",
    "strict": false,
    "sourceMap": true,
    "target": "es2015",
    "module": "es2020",
    "lib": [
      "es2018",
      "dom"
