ArcGIS API for JS 4.15: problem populating pop-up content
2887
10-21-2020 09:00 AM
KayceeFaunce
I'm creating a web map based on this example: https://developers.arcgis.com/javascript/latest/sample-code/sandbox/index.html?sample=tasks-query
Except I've modified it so that the drop-down list is dynamically populated based on the values available in an attribute column (MajBas in this instance). Everything works well EXCEPT that the pop-up content does not display properly after querying a feature. Specifically, only the pop-up title shows but not any of the content.
I'm having trouble figuring out why this would be. I'd appreciate any suggestions you may have for fixing this so that the pop-up content is visible after querying.
<html>
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1,maximum-scale=1,user-scalable=no"/>
    <title>Project viewer</title>
    <style>
      html,
      body,
      #mainViewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
      h2 {
        color: black;
        font-family: "Noto Sans", sans-serif;
        line-height: 1;
      p {
        color: black;
      div {
      line-height: 0;
      #optionsDiv {
        background-color: white;
        color: white;
        padding: 10px;
        width: 100%;
        -webkit-box-shadow: 3px 2px 15px -2px rgba(0,0,0,0.67);
        -moz-box-shadow: 3px 2px 15px -2px rgba(0,0,0,0.67);
        opacity: 0.90;
      #drop-downs {
        padding-bottom: 15px;
      widget {
        /* Fill in later to style drop down widget */
      #printResults {
        line-height: 1;
        font-style: italic;
        font-size: 12px;
        color: black;
      #doBtn {
        box-shadow:inset 0px 0px 0px 0px #9fb4f2;
        background-color:#1a1b1f;
        border: 0px solid #4e6096;
        display:inline-block;
        cursor:pointer;
        color:#ffffff;
        padding:6px 12px;
        text-decoration:none;
        border: 0px;
        outline:none;
        transition: all 0.3s ease 0s;
      #doBtn:hover {
        background-color:#494b51;
        outline:none;
      #doBtn:active {
        position:relative;
        top:1px;
        border: 0px;
        outline:none;
    </style>
    <link
      rel="stylesheet"
     href="https://js.arcgis.com/4.15/esri/themes/light/main.css"
    <script src="https://js.arcgis.com/4.15/"></script>
    <script>
       require([
        "esri/Map",
        "esri/views/MapView",
        "esri/Basemap",
        "esri/widgets/LayerList",
        "esri/layers/FeatureLayer",
        "esri/PopupTemplate",
        "esri/layers/GraphicsLayer",
        "esri/tasks/QueryTask",
        "esri/tasks/support/Query",
        "esri/widgets/Home"
        ], function(
          Map,
          MapView,
          Basemap,
          LayerList,
          FeatureLayer,
          PopupTemplate,
          GraphicsLayer,
          QueryTask,
          Query,
          Home
        var basinUrl =   "https://services.arcgis.com/v01gqwM5QqNysAAi/arcgis/rest/services/Chesapeake_Bay_major_watersheds_feature/FeatureServer/0";
        //* Define the popup content for each result
        var popupTemplate = {
          title: "{MajBas}",
          fieldInfos: [
              fieldName: "MajBas",
              label: "Major basin"
          content:
            "{MajBas} test"
        // Layer - project footprints
       const basinLayer = new FeatureLayer({
        url: basinUrl,
        outFields: ["*"],
        visible: false
        // Layer - dark nav basemap
       const basemap = Basemap.fromId("streets-night-vector");
       //** Point querytask to project boundary URL
        var qTask = new QueryTask({
          url: basinUrl
       //** Set the query parameters to always return geometry and all fields.
       //** Returning geometry allows us to display results on the map/view
        var params = new Query({
          returnGeometry: true,
          outFields: ["*"]
       //* GraphicsLayer for displaying results
       var resultsLayer = new GraphicsLayer();
       var map = new Map({
           basemap : basemap,
          layers: [basinLayer, resultsLayer]
        var mainView = new MapView({
          container: "mainViewDiv",
          map: map,
          popup: {
            highlightEnabled: false,
            dockEnabled: true,
            dockOptions: {
              breakpoint: false,
              position: "top-right"
          center: [-75.325395, 40.306275],
          zoom: 5
        // create home widget
        var homeWidget = new Home({
          view: mainView
         // add widget with drop-down options
        mainView.ui.add("optionsDiv", {
          position: "bottom-left",
          index: 0
        // add home widget
        mainView.ui.add(homeWidget, {
          position: "top-left",
          index: 0
        //* for drop down
        var basinTypeSelect = document.getElementById("valSelect");
         //* query all features from the basin layer
        mainView
          .when(function () {
            return basinLayer.when(function () {
              var query = basinLayer.createQuery();
              return basinLayer.queryFeatures(query);
              document.getElementById("doBtn").addEventListener("click", doQuery);
          .then(getValues)
          .then(getUniqueValues)
          .then(addToSelect)
         //* return an array of all the values in the
        //* basin name field
        function getValues(response) {
          var features = response.features;
          var values = features.map(function (feature) {
            return feature.attributes.MajBas;
          return values;
        //* return an array of unique values in
        //* the MajBas field of the basin layer
        function getUniqueValues(values) {
          var uniqueValues = [];
          values.forEach(function (item, i) {
            if (
              (uniqueValues.length < 1 || uniqueValues.indexOf(item) === -1) &&
              item !== ""
              uniqueValues.push(item);
          return uniqueValues;
         //* Add the unique values to the basin type
        //* select element. This will allow the user
        //* to filter basin by name.
        function addToSelect(values) {
          values.sort();
          values.forEach(function (value) {
            var option = document.createElement("option");
            option.text = value;
            basinTypeSelect.add(option);
        //** Call doQuery() each time the button is clicked
        mainView.when(function () {
          mainView.ui.add("optionsDiv", "bottom-left");
        var attributeName = document.getElementById("MajBas");
        // Executes each time the button is clicked
        function doQuery() {
          // Clear the results from a previous query
          resultsLayer.removeAll();
          // Build new query
          params.where =
            "MajBas =" + "'" + basinTypeSelect.value + "'";
          // executes query and calls getResults() once promise is resolved
          // promiseRejected() is called if the promise is rejected
          qTask.execute(params).then(getResults).catch(promiseRejected);
        // Called each time the promise is resolved
        function getResults(response) {
          // Loop through each results and assign a symbol and PopupTemplate
          var basinResults = response.features.map(function (feature) {
            // Sets the symbol of each resulting feature
            feature.symbol = {
              type: "simple-fill",
              color: [212, 161, 87, 0.25],
              outline: {  // autocasts as new SimpleLineSymbol()
                color: [128, 128, 128, 0.5],
                width: "0.5px"
            feature.popupTemplate = popupTemplate;
            return feature;
          resultsLayer.addMany(basinResults);
          // animate to the results after they are added to the map
          mainView
            .goTo(basinResults)
            .then(function () {
              mainView.popup.open({
                features: basinResults,
                featureMenuOpen: true,
                updateLocationEnabled: true
            .catch(function (error) {
              if (error.name != "AbortError") {
                console.error(error);
          // print the number of results returned to the user
          document.getElementById("printResults").innerHTML =
            basinResults.length + " result(s) found";
        // Called each time the promise is rejected
        function promiseRejected(error) {
          console.error("Promise rejected: ", error.message);
    </script>
  </head>
  <body>
    <div id="mainViewDiv"></div>
    <div id="optionsDiv">
      <h2>Example</h2><br>
        <div id="drop-downs">
          <p><b>Basin</b></p>
        <select id="valSelect" class="widget"></select>
      </div>
      <div align="center"><button id="doBtn">Search</button></div>
      <p><div align="center"><span id="printResults"></span></div></p>
    </div>
  </body>
</html>
RobertScheitlin__GISP
Kaycee,
   The culprit is this css rule.
div {
  line-height: 0;
Kaycee,
div {
  line-height: 0;
KayceeFaunce
That was definitely it! Thank you so much for catching that. I've been combing through the documentation for popup and popupTemplate - it didn't occur to me to look at the css rules as a culprit.
