ArcGIS API for JavaScript Welcome
1120
11-26-2013 07:35 AM
KellyHutchins
Esri Notable Contributor
Welcome to the forums. If you're new to JavaScript and web programming, Dive Into HTML5 and Eloquent JavaScript are two excellent, free resources. If you prefer videos, Crockford on JavaScript is an excellent resource.
If you already have some JavaScript experience, we recommend you start with our tutorials. If you want to start with the API directly, take a look at how to create a simple app. You can also get started by browsing the ArcGIS API for JavaScript samples or the API Reference.
PhuongNguyen_Thanh
I'm waiting for the code assit for AMD coding style in version 3.7 😞
YinShi
I just completed a boilerplate example using ASP.NET Web API, Dojo and ArcGIS API for JavaScript. The client side of the boilerplate is coded using the AMD style. You can get the synopsis of this boilerplate at https://github.com/yinshi/WebApi-Dojo-ArcgisApi-Boilerplate/wiki
The repository is at https://github.com/yinshi/WebApi-Dojo-ArcgisApi-Boilerplate/
GauriDeshmukh
Thanks for the information
Also please provide some reference to the material for dojo/dijit and its use in js api.
