Append div to InfoWindow
1044
01-08-2014 03:22 PM
KarenRobine
I'm trying to figure out the best way to append a Div (with a bunch of HTML) to an InfoWindow. I'm attaching InfoWindows to several different graphics layers. Each one has different formats for attributes. I'm using an onclick event to grab the attributes from the graphics, and insert it into a fairly fancy div. Now, I need the map/pan (extent-change event) to handle setting up the proper anchor with the graphic.
Whats the best method to set this up?
TimCollyer
Can you not set the content of your InfoWindow to be the innerHTML of the div?
Something along the lines of:
var ele = document.getElementById("fancyDiv"); //you will probably be using dom.byId() to do this
infoWindow.setContent(ele.innerHTML);
