API 4.18 Got Console Error After Upgrade Chrome to 128.0.6613.85
2571
08-22-2024 01:29 PM
SonnyTF
Hi All,
Our front-end project with ArcGIS Maps SDK for JavaScript 4.18 worked well on Chrome before it upgraded to 128.0.6613.85. After Chrome was upgraded this morning,  we got many console errors when opening a map with some graphic layers.
After some research, we found it was related to setUniform4fv() method in the Programs.js file. When the "c" is "u_sigmas", "b" comes with [underfinded, undefined, undefined, undefined ]
We can get the same error from the sample code after changing the API to 4.18.
SOandbox | Sample Code | ArcGIS Maps SDK for JavaScript 4.30 | Esri Developer
Other Browers don't have this issue. After upgrading this API  to 4.30 Chrome v128.0.6613.85 got rid of this error too, We also found the same method on API 4.30 gets a null check for "c".
Is there any idea why upgrading Chrome to 128.0.6613.85 will get this error?
Tags (3)
AndyGup
Hi @SonnyTF, try upgrading your SDK version and see if you are still getting the error - latest version is 4.30. Not sure if you were aware, version 4.18 (released December 2020) was retired on May 1st. https://support.esri.com/en-us/products/arcgis-maps-sdk-for-javascript/life-cycle
MichaelVolz
Esteemed Contributor
Another community thread indicates that v4.30 will fix this issue.
SonnyTF
Hi @MichaelVolz ,
Can you share the link to that thread? I searched the community before posting this thread, but I couldn't find any topic related to this.
Sonny
SonnyTF
@AndyGup ,
We can confirm that upgrading to the latest version will eliminate this error. This is just out of curiosity that if any breaking change is made by Chrome in the new version that makes 4.18 not work anymore.
Sonny
AndyGup
