Any changes to renderer 4.1 and 4.2?
1929
02-15-2017 01:50 AM
MarkBalman
Hi All
I have a web map and I am trying to work out why a graphic layer is not rendered when using 4.2. It works fine in 4.0 and 4.1, the code I am using:
        var sppURL = " ";
        var renderer = new UniqueValueRenderer({
          field: "SLD",
          //defaultSymbol: new SimpleFillSymbol({color:null, outline: null})
        // Add a unique value info
        renderer.addUniqueValueInfo(1,
            color: [51, 160, 44, 0.6],
               style: "solid",
            outline: null
        renderer.addUniqueValueInfo({
          value: 2,
          symbol: new SimpleFillSymbol({
            color: [235, 232, 53, 0.6],
            outline: null
      var sppLyr = new MapImageLayer({
          url: sppURL,
          popupTemplate: {
            content: "
              sublayers: [
              visible: true,
              definitionExpression: "ID = 'SppID'"
  •        var resultsLayer = new GraphicsLayer({renderer: renderer});
    When switching to 4.2 api I get the following error (in Firefox):
    Uncaught TypeError: Cannot read property 'type' of null
        at f.get [as isPolygonMarkerSymbol] (MapView.js:365)
        at f._projectGeometry (MapView.js:369)
        at f.render (MapView.js:367)
        at d.renderChild (MapView.js:364)
        at d.renderChildren (MapView.js:259)
        at d.render (MapView.js:255)
        at m.renderChild (MapView.js:290)
        at m.d.renderChildren (MapView.js:259)
        at m.d.render (MapView.js:255)
        at m.render (MapView.js:289)
    Any advice welcome as not sure what to do now.
    Mark
    RobertScheitlin__GISP
