Another support issue about Print Map
1031
08-06-2013 04:59 AM
MustafaOgurlu
Is there support for PrintMap Tool with
projected ArcGISTiledMapServiceLayer? at js 3.5 api.
I think not
JasonZou
Which PrintMap tool are you using? I've used the PrintTask, and it works with esri base maps which are tiled map services.
MustafaOgurlu
I use:  https://developers.arcgis.com/en/javascript/jssamples/widget_print_esri_request.html
If I use Esri base map has, there is no problem.  But if I use a projected cached map service: There is problem.
