angular asp net6 read appsettings.json file Failed to compile
1250
08-26-2022 03:14 PM
DimaY
./node_modules/read-appsettings-json/dist/index.js:27:24-60 - Error: Module not found: Error: Can't resolve '../../../appsettings.json'
DimaY
https://www.npmjs.com/package/read-appsettings-json
I did everything that is written here on this link, but it does not work.
ReneRubalcava
Esri Frequent Contributor
This isn't a project related to the ArcGIS JSAPI. You might want to try stackoverflow as the github repo for that project no longer exists, so I'm guessing it's no longer maintained.
