An error occurred when starting a widget embedded within InfoWindow: Cannot read property '1' of null
3398
11-04-2015 01:39 PM
TrevorMasters
I am getting the above error (init.js:919 API v3.14) identifying a feature in a javascript map viewer, when calling `infoWindow.setFeatures(featureSet);`. The problem is caused by a map service having field aliases with trailing colons in them. The following is part of the json returned from the map service query (geometry removed).
I can see the problem, but not sure how to go about fixing it? Is it caused by the json deserialization, serialization by the REST API (10.3.1 server), or a bug in the javascript API?
If I only choose outfields that have no trailing colon, it works. I have no control over the offending map service.
"results":[{
  "layerId":37,
  "layerName":"Waste Water Lateral",
  "displayFieldName":"Unit ID:",
  "value":"NP-MANGO0131SL/1",
  "attributes":{
  "OBJECTID":"2474425",
  "Depth":"0.6",
  "SHAPE":"Polyline",
  "Install":"Null",
  "Unit ID:":"NP-MANGO0131SL/1",
  "Owner:":"W&W",
  "Asset ID:":"115807",
  "Comments:":"Null",
  "NPDC_VECTOR_SDEADMIN_SVEW_WWLATERAL_area":"NP",
  "SHAPE_Length":"8.117518"
  "geometryType":"esriGeometryPolyline"
// geometry removed
FrankJohnson
Im not sure if your JSON code is bad or you pasted part of the code you have. Your closing bracket is in the wrong position.
//geometry removed
}  -- This is closing the top of the code.. you have it inside the results declaration. Move it and see if you still get the error.
TrevorMasters
Sorry, It is my copy/paste that is incorrect - I tried to simplify the example by removing lines, and adding newlines. The key thing is the trailing colon (:) in any field name. The response Json looks correct (e.g. "Comments:":"Null") but this gets interpreted as "Comments"::"Null".
