"SnapToLevels"  equivalent in JS API?
1392
03-28-2013 12:32 PM
MeleKoneya
In the Silverlight API Map Class , there is a Map.SnapToLevels property which
"Gets or sets whether zooming will snap to scale levels if the map contains cached layers".
I do not see the same property in the JS API,  but I was wondering if someone had found a way to zoom "in between" cached layers in a Tiled Map Service.
Mele
JeffPace
MVP Alum
Mele
I believe in the JS api this is not possible.  YOu must zoom to a level if there are tiled layers.
ShaunWeston
Is there a way in the Javscript API to zoom in beyond the cached levels, but still show the cache?
OrenGal
I don't think so. If you have multiple cache layers you can 'jump' between the scales only of the bottom cache.
JianHuang
It will support it in the next release. It will allow you to go to higher levels where there are no data available. Please note, you also need tiled map service on arcgis server 10.2 in order to do this.
