"Display Visible Fetures" Sample not working on IE 7 and 8.
1374
05-16-2011 12:48 PM
HemingZhu
Just run across the "Display Visible Fetures" Sample. It seems not loading features on dojox.grid.DataGrid  on IE 7 and 8. It works fine on other major browsers. Does someone have the same issue?
KellyHutchins
Esri Notable Contributor
Can you post a link to the sample that is broken in IE?
HemingZhu
KellyHutchins
I justed tested it in IE8 and it loaded data into the grid but it took several seconds.
HemingZhu
Kelly,
Did you test it on JS API 2.3 ? The sample seems work now under JS API 2.3.  I did a little test. I copy the sample and changed the version to 2.2. The Data Grid is not loading properly again! It does not matter now since i will use the newer version. Thanks for testing.
