AMD - Dojo Build
1682
08-29-2012 03:15 PM
DanielBradshaw
I'm trying to put together a build of a simple application that uses AMD modules.  The Dojo build documentation states that I need a copy of the Dojo SDK source, but I'm concerned that the merged Dojo / ESRI javascript libraries might conflict with another full copy of Dojo in my source files.
Has anyone created a build release of their javascript apps using the Dojo build process (or r.js process using the latest javascript api)?  If so, can you share any lessons learned?
DB
ReneRubalcava
Esri Frequent Contributor
I'm no help on the dojo build. I tried getting it set up, but after a few tries I just went back r.js.
With a fold structure like this.
release/
src/
- index.html
- js/
- stylesheets/
- templates/
I have a documented app.build.js file looks like this.
 * This is the build file I have started using
 * to build my ArcGIS JS API 3.0 apps, which are
 * based on Dojo 1.7. I used a similar build file
 * when I was using Require.js, so it wasn't much different.
 * I tried using the Dojo Build Tools, but it just seemed
 * way too bloated to download the Dojo SDK, sort my files,
 * blah blah blah. With r.js I can use Node NPM to
 * npm install requirejs and just use the following command
 * r.js -o src/js/app.build.js
 * Done and done!
 * This build file is meant to be used with r.js
 * http://requirejs.org/docs/optimization.html
 * For more details on options, you can review
 * the sample r.js build file
 * https://github.com/jrburke/r.js/blob/master/build/example.build.js
  appDir       : "../",
  baseUrl      : "js",
  dir          : "../../release",
  paths               : {
    "jquery"          : 'libs/jquery/jquery-1.7.2.min',
    "jqueryui"        : 'libs/jqueryui/jquery-ui-1.8.20.custom.min',
    "jquery.boostrap" : 'libs/boostrap/bootstrap.min',
    "underscore"      : 'libs/lodash/lodash.min',
    "backbone"        : 'libs/backbone/backbone-min',
     * This is key. Since the namespaces of dojo & esri,
     * even dojox and dijit come from the ArcGIS CDN, use the
     * empty: scheme so r.js doesn't try pull in these
     * dependencies.
     * http://requirejs.org/docs/optimization.html#empty
    "dojo" : "empty: ",
    "esri" : "empty: ",
    "text" : "empty:"
   * r.js uses uglifyjs by default.
   * https://github.com/mishoo/UglifyJS/
   * If you run r.js via java, you can use google closure.
   * I tried to integrate closure, but java on my work
   * machine kept punching me in the face. Stick with uglify,
   * a dude on twitter told me it was faster anyway.
  optimize : "uglify",
   * This doesn't work as intended for me.
   * According to docs and google groups, this
   * should remove all combined files when
   * optimizing a whole project
  //removeCombined      : true,
   * This option will grab all the text! calls and
   * place them in your optimized file to avoid
   * making XMLHttpRequests to load the files
  inlineText          : true,
   * This is optional, as setting the modules
   * will create a combined file of all dependencies
   * in the release folder. You get a single larger file
   * to load rather than multiple smaller files.
   * Use at your own discretion.
  modules  : [
       * I optimze my app file, because I use
       * my main file to set up my dojoConfig.
       * If doing a single js file optimization,
       * DO NOT include the dojoConfig file
       * to be included. It will blow you up.
       * Optmize the next entry point into your app.
   * Will make your css a single line file
// I had an issue in one app where this caused some issues. Didn't track it down, but only
// happened in the one app. I should look into it further. Just disable if it causes problems.
  optimizeCss         : "standard",
   * Ewww, RegEx. It's easy though,
   * just include files/folders you don't want to
   * get exported to your release build folder.
  fileExclusionRegExp : /\.(coffee|coffee~|js~|html~|css~|swp|rb|lnk)|sass|.sass-cache|build/
Hope that helps.
DanielBradshaw
Odoe -
Thanks for the follow-up.  I'm glad to know that I can still use the require optimizer (easier to use).  And thanks for the inspiration!  I've already been using your github apps as a gut-check for the some of the work I've been doing.
Anybody else out there use the Dojo build process with the latest javascript API?
DB
