Algorithm/Javascript code for esri.geometry.toScreenGeometry()
1389
03-14-2013 01:48 AM
NiranjanBorawake
Can some one please share or point me to an algorithm and/or javascript code (actual implementation) of the ArcGIS' esri.geometry.toScreenGeometry(extent, width, height, screenGeometry) geometry service. Details at
geometry service details.
I have to get screen geometries for about 15,000-20,000 points. Calling above geometry service in loop takes substatial amount of time around 5 secs for 15,000 points.
I am looking for a javascript function which would take input as above service and return me screen geometyr object.
I have already got a javascript function for this esri.geometry.geographicToWebMercator(geometry) service.
Niranjan
RahulMetangale1
Niranjan,
I do not think esri.geometry.toScreenGeometry calls geometry service. it will perform calculation on client side.
Rahul
NiranjanBorawake
Hi Rahul,
Yes, you seem to be right, the calculation is performed at client side and no service is called.
But is there a chance where I can get the algorithm that does this.
My plan is to implement this algo in java code so that I reduce the work that is done on browser.
Niranjan
