Adding the features to existing layer
5449
15
09-12-2013 02:00 AM
ChiranjeeviGK
Hi all
I am new to GIS, i have created a online account with ersi and created a map
Need to make a application which i need to add the features on that map
Please help me or guide me how to do this
ChiranjeeviGK
Hmm ok.. let me tell this way
here in the below tutorial
https://developers.arcgis.com/en/javascript/jssamples/ags_editor.html
we can add the markers to the map and it will save to ArcGIS.com
so i need to do the same on the my map, which i have created in my content
need to write the code for that, so need you help. how to save those markes?
-chiru
JohnGravois
i understand the problem now.  you are displaying CSV data in your webmap, but this is not the same thing as converting CSV data to be a hosted feature service.
please follow the steps in the article i linked to above (called "Publishing a hosted feature service using a shapefile or CSV file"), and add that new data source to your webmap instead of adding the CSV content directly.
hosted feature services are editable from within web applications.  dynamically drawn CSV data is not.
ChiranjeeviGK
i dont have problem with data or the published CSV file,
my problem is different
in this sample code we can add the features right?
same thing i have to do by replacing the webmap id.
if i replace the web map id its not showing the left side pane, the markers.
-chiru
JohnGravois
there are no markers in the side panel of your map because your webmap doesn't contain any hosted feature services.  please review my comments above to resolve that problem.
ChiranjeeviGK
i have added a hosted feature which is public too..
[ATTACH=CONFIG]27441[/ATTACH]
tell me what i have to do with that..
sorry i am new to this..
JohnGravois
you need to add the hosted feature service as a data layer in your webmap.
What layers can you add to your map?
http://resources.arcgis.com/en/help/arcgisonline/index.html#/What_layers_can_you_add_to_your_map/010...
