add token
1343
01-11-2018 12:40 PM
anjelinaponkerat
Hi
How to define token for services like feature service and map service?
RobertScheitlin__GISP
In Javascript the recommended approach is to use the esri resorces proxy and NOT generate your own token.
anjelinaponkerat
Is there any clear help for set proxy and define it on js aplication?
Anjelina,
   Sure there are dozen of threads about this.
Here is a link to the blog links that those threads would direct you to:
https://community.esri.com/groups/technical-support/blog/2015/04/07/setting-up-a-proxy
And here is the proxy github page:
GitHub - Esri/resource-proxy: Proxy files for DotNet, Java and PHP.
