Add polygon coordinates via dynamic variables
2925
10-21-2015 03:44 PM
JonathanCzerniak
Hi everybody!
I have a function which takes the XY coordinates from a point layer and then passes those coordinates to a couple of variables.  Those values are then assigned to other values which compute 4 coordinate pairs which are meant to be used as a list of coordinates to a create polygon via the esri/geometry/Polygon module.
Passing the values works like a charm and the additional variables are all defined.  In fact the entire code runs, but it doesn't produce the desired results which is a square.
Side note: I know it's the variables because if I assign some hard numeric values to the addPoly function and not the variables the desired polygon will be produced.  Thanks for your time!
Cz
function addPoly(){
        //assign values to the square coordinates
        var x1 = Number(xpoint + 201.168);
        var y1 = Number(ypoint + 201.168);
        var x2 = Number(xpoint + 201.168);
        var y2 = Number(ypoint - 201.168);
        var x3 = Number(xpoint - 201.168);
        var y3 = Number(ypoint - 201.168);
        var x4 = Number(xpoint - 201.168);
        var y4 = Number(ypoint + 201.168);
     //check to see if values were assigned
     alert("Your values are " + x1 + " " + y1);
        //add polygon symbology
        var polySymbol = new SimpleFillSymbol().setColor(null).outline.setColor("blue");
        var polyLineSymbol = new SimpleLineSymbol();
        var polygon = new Polygon({
            "rings": [
                [y1, x1],
                [y2, x2],
                [y3, x3],
                [y4, x4],
                [y1, x1]
            "spatialReference": {
              "wkid": 102100
          alert("graphic should add next");
        map.graphics.add(new Graphic(polygon, polySymbol));
