add layer satellite map.
5667
04-18-2015 10:05 AM
lasinh
How to add layer satellite in to my Map! thank you!!
YousefQuran
map = new Map("map", {
        basemap: "satellite",
        center: [-105.255, 40.022],
        zoom: 13
OwenEarley
See this sample - Create a map | ArcGIS API for JavaScript
As Yusuf Ali has already mentioned use the "satellite" basemap when creating the map (instead of the topo one that is used in the sample).
lasinh
i have my  basemap, i want add layer satellite above the basemap
OwenEarley
The map object only supports displaying a single basemap layer at any time so you would need to add a layer to your map. To do this just use one of these:
Replace the URL with the endpoint of your satellite imagery source.
YousefQuran
    url:"http://services.arcgisonline.com/arcgis/rest/services/ESRI_Imagery_World_2D/MapServer/0
Add this Feature Layer to the map, but I do not know if it will works fine or not ... 'How to add Satellite above your basemap?', anyways try it!
