Add layer from Arcgis Server to API Javascript
6172
01-27-2015 01:31 AM
VincentChoffrut
Hello everyone,
I would like to add a layer (stored with arcgis server on localhost -as you can see with the url) on my map (and this SHOULD be quite simple).
can someone tell me why this simple script isn't working? (it loads the topo basemap, ok, but NO LAYER)
<script>
            var map;
      require
            (["esri/map",
                "esri/layers/FeatureLayer",
                "dojo/domReady!"],
                    function(Map,
                    FeatureLayer)
                            var map = new Map("map",
                            basemap: "topo",
                            center: [0.694357, 47.395560],
                            zoom: 8
                            var rivers = new esri.layers.FeatureLayer("http://localhost:6080/arcgis/rest/services/CARTAGES/Lineaire_Hydro_Loire_Bretagne/MapServer");
                            map.addLayer(rivers);
    </script>
thanx a lot in advance
vincent
KenBuja
MVP Esteemed Contributor
When you add a FeatureLayer, you have to specify a single layer within the service.
var rivers = new FeatureLayer("http://localhost:6080/arcgis/rest/services/CARTAGES/Lineaire_Hydro_Loire_Bretagne/MapServer/0");
From the Help‌:
The feature layer inherits from the graphics layer and can be used to display features from a single layer in either a Map Service or Feature Service.
TimWitt2
Vincent,
try the following:
<script>
            var map;
      require
            (["esri/map",
                "esri/layers/ArcGISTiledMapServiceLayer",
                "dojo/domReady!"],
                    function(Map,
                    ArcGISTiledMapServiceLayer)
                            basemap: "topo",
                            zoom: 8
                            var rivers = new ArcGISTiledMapServiceLayer("http://localhost:6080/arcgis/rest/services/CARTAGES/Lineaire_Hydro_Loire_Bretagne/MapServer");
    </script>
Hope this helps!
Tim
VincentChoffrut
I had already tryed using the tiledmapservice but it doen't provide any display (at all, in my simple case, I mean).
Thanx a lot, Tim, for your answer & advice!
greetings from paris, anyway
vincent
KenBuja
From the Help‌:
VincentChoffrut
THAT'S IT
thank you Ken, like, a million times!!!
