Add inset box-shadow to the map div?
1759
08-25-2014 09:43 AM
AlexGole
Hi all,
I am looking to use an inset box-shadow to the map. Using Firefox I noticed that I could do so modifying the style of map-gc (svg). However when I apply the change to the map in my css stylesheet i dont get anything. Any of you have a clue how to a box-shadow? I am using JQuery layout UI.
Thank you,
Alex
Tags (3)
RobertScheitlin__GISP
Alex,
     As this question is a duplication (generally) of this one Map shadow‌that has an answer.
If you don't mind as a moderator I will delete this one (let me know if you are OK with that).
