Add graphic not successufl
8307
30
01-03-2014 05:07 AM
ShaningYu
Honored Contributor
I tested my 1st JS API application.  My code is below:
            var polylineJson = {      'paths': [     [
                  [201394.01178484457,173661.08635829584],
                  [201392.0117168416,173661.08690949593],
            var polyline = new esri.geometry.Polyline(polylineJson);
            var polylineSymbol = new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([46, 139, 87, 1]), 5);
            map.graphics.add(new esri.Graphic(polyline, polylineSymbol));
But the polyline is not added on the map.  What's wrong in the code? Thanks if you can help.
JonathanUihlein
It's because you are still using points and assigning the wrong spatial reference.
var polylineJson2 = {  "paths":[[[201394.01178484457,173661.08635829584],[201392.0117168416,173661.08690949593],[  201388.01158083565, 173661.08801189612 ],[ 201386.01151283266,  173661.08856309619 ],[ 201384.0114448297, 173661.08911429628 ],[  201382.0113768267, 173661.08966549637 ],[ 201380.01130882374,  173661.09021669647 ],[ 201378.01124082075, 173661.09076789653 ] ]  ],"spatialReference":{"wkid":102100} };
These points are not 102100.
An example of coordinates with a spatial reference of 102100:  [-7900279.71, 5103864.38]
I tried taking one of your path coordinates and was able to add a point to the map using a spatial reference of 26973 (as you mentioned earlier in the thread) and it was successful.
Sample below; click on the points to print data about that point in the console.
However, like I said, you will need to convert your data into a usable format.
The other potential option is to use a custom basemap with a spatial reference of 26973 (but I feel like this is more work overall).
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="X-UA-Compatible" content="IE=7,IE=9">
<meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
<title>Build your first application</title>
<link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.8/js/esri/css/esri.css">
<style type="text/css">
html, body, #map {
padding: 0;
margin: 0;
height: 100%;
</style>
<script src="http://js.arcgis.com/3.8/"></script>
<script>
var map;
require(["esri/map", "dojo/ready", "dojo/on", "esri/geometry/Polyline", "esri/graphic", "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleMarkerSymbol", "esri/SpatialReference", "esri/geometry/Point", "dojo/domReady!"], function(Map, ready, on, Polyline, Graphic, SimpleLineSymbol, SimpleMarkerSymbol, SpatialReference, Point) {
  var map = new Map("map", {
  center: [-122.58, 45.55], //longitude, latitude
  zoom: 3,
  basemap: "streets",
  slider: true, //default
  sliderPosition: "top-left" //default
  ready(function (){
    on(map, "load", drawPath);
    on(map, "click", function(evt){
       if (evt.graphic) {
       console.log("Graphic Object:", evt.graphic);
       console.log("Spatial Reference Object:", evt.graphic.geometry.spatialReference);
       console.log("type:", evt.graphic.geometry.type);
       console.log("wkid:", evt.graphic.geometry.spatialReference.wkid);
       console.log("X:", evt.graphic.geometry.x);
       console.log("Y:", evt.graphic.geometry.y);
    function drawPath(){
      var polylineSymbol = new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 3);
      var polylineJson = { "paths":[[[-122.68,45.53], [-122.58,45.55], [-122.57,45.58],[-122.53,45.6]]], "spatialReference":{"wkid":4326}};
      var polyline = new Polyline(polylineJson);
      var polylineGraphic = new Graphic(polyline, polylineSymbol, null, null);
      map.graphics.add(polylineGraphic);
      var pSymbol = new SimpleMarkerSymbol().setStyle(SimpleMarkerSymbol.STYLE_CIRCLE).setColor("#FFFF00");
      var pnt = new Point(-122.58, 45.55, new SpatialReference(4326));
      var pointGraphic = new Graphic (pnt, pSymbol);
      map.graphics.add(pointGraphic);
      try{
        var testSymbol = new SimpleMarkerSymbol().setStyle(SimpleMarkerSymbol.STYLE_CIRCLE).setColor("#FF0000");
        var testPoint = new Point(201394.01178484457, 173661.08635829584, new SpatialReference({wkid:26973});
        var testGraphic = new Graphic (testPoint, testSymbol);
        map.graphics.add(testGraphic);
      }catch(e){
        console.log(e);
</script>
</head>
<body class="claro"></body>
</html>
Could you post the latitude and longitude of your coordinates?
KenBuja
MVP Esteemed Contributor
It's not that these coordinate aren't 10200. They're just located very close to 0°N, 0°W
JonathanUihlein
Could you take my code and modify it to work with his path by chance?
Should be a 5 minute job with the code posted above.
Thanks!!!
ShaningYu
Honored Contributor
To Jon:
Changed the wkid to 26973 but still not drawing.  Wish have additional hint from you.  Thanks.
var polylineJson2 = {  "paths":[[[201394.01178484457,173661.08635829584],[201392.0117168416,173661.08690949593],[  201388.01158083565, 173661.08801189612 ],[ 201386.01151283266,  173661.08856309619 ],[ 201384.0114448297, 173661.08911429628 ],[  201382.0113768267, 173661.08966549637 ],[ 201380.01130882374,  173661.09021669647 ],[ 201378.01124082075, 173661.09076789653 ] ]  ],"spatialReference":{"wkid":26973} };
By the way, your previous script (received 2 days ago) works, but the 1 you posted today does not.  I just wonder why the polyline2 could not be drawn.  Thanks.
ShaningYu
Honored Contributor
This is the message for you to catch up my updated thread.
JonathanUihlein
Opps! Forgot a ) on this line:
var testPoint = new Point(201394.01178484457, 173661.08635829584, new SpatialReference({wkid:26973}));
ShaningYu
Honored Contributor
No map displays on my IE.  Totally empty page.  I don't know why.  Maybe the basemap not added?
JonathanUihlein
Please, no reason to be rude Shaning.
Still waiting for Ken to generate a working sample.
ShaningYu
Honored Contributor
Of course no reason to be rude.  Actually, your work is very APPRECIABLE.  Have a nice weekend.  I will continue my work next Monday.  Again, THANKS so much for you valuable time and experience.
KenBuja
I think what you're going to have to do is use a Geometry Service to project it. If I use Jon's code, I get a point at 0, 0.
[ATTACH=CONFIG]30405[/ATTACH]
I went to this sample, added the wkid 26973 to the list, and used the geometry service to get the projected coordinate, which comes out to be somewhere in Kentucky (-84.5304109050132, 36.8066895277335). Not surprising, since this wkid is Indiana State Plane (NAD_1983_StatePlane_Indiana_East_FIPS_1301).
