Add a dynamic map Service layer on Esri basemap
3631
09-10-2014 10:01 PM
RichardMoussopo
I am trying to add a  map Service layer on Esri basemap and no success. I am wondering if it is possible to do so?
RobertScheitlin__GISP
Richard,
What have you tried? Is the layer you are adding to the map in WKID 102100 (Web Mercator) as esri basemaps are? Are you adding an ArcGISDynamicMapServiceLayer or an ArcGISTiledMapServiceLayer? You need to provide more detail when you post and code snippets if possible.
Robert
AntigoniKoffa
You can try something like the following example.If the dynamic service has different projection than web mercator, it will be reprojected on the fly.
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Create Map and add a dynamic layer</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css"/>
    <style>
      html, body, #mapDiv{
        padding: 0;
        margin: 0;
        height: 100%;
    </style>
    <script src="http://js.arcgis.com/3.10/"></script>
    <script>
      var map;
      require([
        "esri/map",
        "esri/layers/ArcGISDynamicMapServiceLayer",
        "esri/layers/ImageParameters"
      ], function (
        Map, ArcGISDynamicMapServiceLayer, ImageParameters) {
        map = new Map("mapDiv", {
          basemap: "streets",
          center: [-83.244, 42.581],
          zoom: 15
        var imageParameters = new ImageParameters();
        imageParameters.format = "jpeg"; //set the image type to PNG24, note default is PNG8.
        //Takes a URL to a non cached map service.
        var dynamicMapServiceLayer = new ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Population_World/MapSer...", {
          "opacity" : 0.5,
          "imageParameters" : imageParameters
        map.addLayer(dynamicMapServiceLayer);
    </script>
  </head>
  <body>
    <div id="mapDiv"></div>
  </body>
</html>
PaulCrickard1
I will add that I have had an issue with this. I took the example from ESRI and changed the URL to my server and nothing. If I make it a L.esri.FeatureLayer and add the /0 - or whichever feature - to the end of the URL, it displays fine. I just figured our services were published differently.
