Accessing the JS API via a web worker
13497
28
05-15-2017 02:51 PM
RobertHewlett
I would like to offload some of the heavy lifting in a web app to a web worker.
It is a 2-3 second jank I would like gone.
Right now the web worker would still need access to parts of the API e.g. Extent and Polygon.
I have tried loading the init.js script via importScripts() but I still get errors.
Has anyone had any success with the ArcGIS JS-API inside a web worker ... not outside but inside.
RobertHewlett
Hi Rene,
I am newbie on this part of the API so my conceptual thinking might be off but ....
Is proxy.connection.invoke basically the worker invoking one of its own methods/functions as this is usually done from the client side.
OR
Is the there a list of client side objects you can send into the worker and from within the worker call these methods/functions back in the client.
Rob
ReneRubalcava
Esri Frequent Contributor
It's not invoking a method on itself, the proxy.connection invoking a method on the object you are passing to workers.open(), that exist on the client. It can be anything you want, it just needs to have a method that returns a promise, because it's also a way for you to request information from the main thread from within the worker.
RobertHewlett
"You can then invoke any functions from the worker on this argument.
What if the function updated the client UI? BOOM?
RobertHewlett
Just a heads up for others. Once I started using the proxy.connection as shown in the gist-sample the variable names on the client-side and the web-worker side had to match.
This might be a chrome-thing, transferable object-thing or a AJS-connection framework-thing. Not sure as I am a newbie to this part of the API.
If I do this on the non-web-worker side
 return connection.invoke("someFX", { argsAsJSON });
Then inside the web-worker I had to make the variable names match:
       Request.prototype.someFX = function someFX({argsAsJSON}, {proxy}) {
If I used another variable name then that variable would be undefined:
       Request.prototype.someFX = function someFX({data}, {proxy}) {
The line above (in the chrome debugger) would report data as undefined.
RobertHewlett
Can a FeatureSet be used inside a worker?
I am currently getting this error.
ErrorEvent {isTrusted: true, message: "Uncaught TypeError: Cannot read property 'compatMode' of null", filename: "http://js.arcgis.com/4.3/dojo/dojo.js", lineno: 168, colno: 316}
bubbles
false
cancelBubble
false
cancelable
true
colno
316
composed
false
currentTarget
Worker
defaultPrevented
true
error
null
eventPhase
filename
isTrusted
true
lineno
168
message
path
Array(0)
returnValue
false
srcElement
Worker
target
Worker
timeStamp
5463.285000000001
type
"error"
__proto__
ErrorEvent
RobertHewlett
Below is a copy of my define()
define([
    "esri/config",
    "esri/core/promiseUtils",
    "esri/geometry/geometryEngine",
    "esri/geometry/Extent",
    "esri/geometry/Polygon",
    "esri/tasks/support/FeatureSet"
], work);
So far the worker works until I add:
RobertHewlett
Enjoy!
RobertHewlett
Updated video.
MichalGasparovic
Apologies for digging out this old thread. I'm running into the issue with the huge amount of requests and it's been recommended to do my own build. Let's assume I have it, how do I provided it to the worker?
https://community.esri.com/message/790617-re-web-worker-and-js-api-modules
