Accessing Session Variables in .JS page
1699
08-19-2014 01:44 PM
jaykapalczynski
Honored Contributor
I have my Session variable accessible at the .ASPX page....
But I also have a .JS page that is defining the map and layers to render.
I need to get the session variable in the .JS page....cant figure out how to...
Anyone have any thoughts?
I am trying to get the value of the Hidden Input type in .JS page like this
IN .JS PAGE
var varToken = registry.byId("tokentext");
alert(varToken);
In the .aspx page and .aspx.vb page I can alert the Session variable as such
IN .NET
Protected Sub Page_Load(sender As Object, e As EventArgs) Handles Me.Load
   tokentext.Value = Session("tokentext")
End Sub
IN .ASPX PAGE
<form id="form1" runat="server">
  <div>
   <asp:Label ID="tlabel" runat="server"></asp:Label>
  <input type="hidden" id="tokentext" name="tokentext" runat="server"/>
  <asp:Button ID="Button1" runat="server" Text="Button" style="margin-left: 55px" />
  </div>
  <script type="text/javascript">
        var tvalue = document.getElementById('<%= tokentext.ClientID%>').value
        alert(tvalue);
  </script>
</form>
jaykapalczynski
Honored Contributor
Was able to get the value from the Hidden Input as such
var test = document.getElementById('tokentext').value
alert('Returned Session variable: ' + test);
jaykapalczynski
Honored Contributor
jaykapalczynski
Honored Contributor
Update:
Was then able to parse the return....
This is what the tokentext.value looks like:
{"token":"bgfhf87999999hdhwsu8d.","expires";1408485233476}
var JsonParseToken = JSON.parse(test);
var MapServerToken = (JsonParseToken.token);
alert(MapServerToken);
