Accessing Drawing Info
2398
09-06-2012 03:22 AM
PramodHarithsa1
Is there a way to access the drawing info of layers.?
I use a ArcGIS server Version 10.0
[ATTACH=CONFIG]17514[/ATTACH]
I see only these set of properties accessable with layerinfos
[--EDIT--]
From the doc's i see
If the layers are version 10 or lower the legend is created using the ArcGIS.com legend service. In order to use the ArcGIS.com legend service your map service needs to be publicly accessible and your application must be able to access ArcGIS.com.
There is similar dependancy on Drawing Info as well i guess.
(In my case map service is not publicly available)
__Rich_
Which Service Pack?
PramodHarithsa1
Which Service Pack?
ArcGIS Server Version: 10.0.0.0
__Rich_
Can you apply a service pack:
http://support.esri.com/en/downloads/patches-servicepacks/list?productid=107&productVersions=10&cate...
Otherwise, can you get enough information from:
http://<your ags>/rest/services/<your service>/MapServer/<layerId>?f=json
PramodHarithsa1
Not sure of applying service pack..
converting to json surely gives me enough info
Thanks..
Now how do i hit this URL from Jscript?
__Rich_
Do you administer the server is there another team?  Instructions are provided on the download page.
Thanks..
You're welcome.
I think you should at least make an attempt to work that out for yourself 🙂
