Access Map Object in developer console in ArcGIS JavaScript viewer
1166
06-21-2019 02:23 AM
MartinSirkovsky1
Hi.
I am trying to get access to map object in developer console, when using a ArcGIS JavaScript Map viewer avaialable in REST API.
I want to use it for example to read or modify map scale, get a current extent and other functions. However I am not able to figure out how to access the object. I could read the scale, from the "map" DOM element, but I would like to have access to the map object. I believe there is a way to do it.
Thank you
Martin
