Access-Control-Allow-Origin and 3.0
6834
06-19-2012 08:19 PM
JohnCartwright
Hello All,
I'm finding that when using 3.0, I get the following error:
XMLHttpRequest cannot load http://server.arcgisonline.com/ArcGIS/rest/info?f=json. Origin http://localhost is not allowed by Access-Control-Allow-Origin.
Simply switching the API back to 2.8 eliminates the problem.  I've tried configuring both CORS and the proxyUrl, but neither helps.
Can someone please provide me some guidance here?
Thanks!
--john
derekswingley1
Hi John,
You can safely ignore these errors. There's info about this in the doc for esri.request (specifically, the bullet for 3.0).
Kelly also posted about this a couple of days ago:  http://forums.arcgis.com/threads/59988-Issue-Upgrading-to-version-3.0?p=207055&viewfull=1#post207055
JohnCartwright
Thanks Derek, I had not seen Kelly's message on this topic.  I'm surprised though that http://enable-cors.org/ reports that sservices.arcgisonline.com is a CORS-enabled site.
--john
derekswingley1
Glad to help.
Attached is what I see when I used enable-cors.org to check if CORS is supported on services.arcgisonline.com. That server is not set up for CORS.
AaronConnolly
Ignoring this warning doesn't work if you call a buffer task:
http://forums.arcgis.com/threads/78905-GeometryServic-Buffer-Task-amp-Access-Control-Allow-Origin?p=...
Why would this happen with a geometry service? I'm running API version 3.2.
