About / Details / Info Widget? Splash?
1506
09-10-2022 10:20 PM
StefanFreelan
Hey All,
I'm looking for a simple About widget (for map details, credits and info). Seems like a pretty basic widget but I'm not finding any sample code... (maybe it's so basic that samples aren't needed).
Or maybe a Splash screen (that can be re-activated via a button from the map)?
Anyone got an example they'd like to share?
the most basic button with a "?" on it that opens a pop-up with text / images / links is all that I'm looking for.
thanks,
~stefan (JS novice)
Tags (4)
Noah-Sager
Maybe you're looking for the Attribution widget?
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Attribution.html
There's also the ? button on the left side of this sample with instructions on how to use the sample. It can be opened and closed repeatedly:
https://developers.arcgis.com/javascript/latest/sample-code/layers-mapnoteslayer/
StefanFree
Thanks Noah,
The ? button code in the MapNotesLayes sample is exactly what I was looking for.
(If I could figure out how to mark this as an Accepted / Solution I would, but I can't find that option anywhere...)
