A Point / Line not drawn on map
4460
03-10-2015 08:51 AM
ShaningYu
Honored Contributor
I have an JS application, which could add queried point / line on the map.  But now, the point / line queried does not display on the map.  It means it is not drawn.  What is the possible reason to cause the problem?  Thanks if you can share your experience.
KenBuja
MVP Esteemed Contributor
Please post your code to help us assist you
OwenEarley
If this is the result of a QueryTask then you need to handle adding the results to the map. Check out this sample - specifically how the addPointsToMap function is used to add the results to the map.
ShaningYu
Honored Contributor
Problem found to be projection related.  Thanks to the reviewers.
