4.7 - I need to add "http://localhost:44300" into CORS policy for debug my project.
11250
17
05-13-2018 11:18 PM
TubaKumbara
Hello.
I'm developing sceneView application and i can't see basemaps when i debugging my project on localhost (pressing F5). Because CORS policy blocking my localhost. But i see no error when i published my project.
I tried to add
esriConfig.request.corsDetection = false;
But doesn't worked.
AccessTo image at "https://myproxyserver/resource-proxy/proxy.ashx?http://myserver.com/myservice/3/5/1.jpg" from origin "https://localhost:44300" has been blocked by CORS policy: No "Access-Contol-Allow-Origin" header is present on the requested ressource. Origin "https://localhost:44300" is therefore not allowed access
Thanks inadvance.
TubaKumbara
Yes Exactly
My machine name is "goldone".
proxy.config
<serverUrl URL="http://goldone" matchAll="true" />
<serverUrl URL="http://goldone:44300" matchAll="true" />
<serverUrl URL="https://goldone" matchAll="true" />
<serverUrl URL="https://goldone:44300" matchAll="true" />
JS file
urlUtils.addProxyRule ({ urlPrefix: "http://goldone", proxyUrl: "https://proxrserver/proxy.ashx"});
urlUtils.addProxyRule ({ urlPrefix: "http://goldone:44300", proxyUrl: "https://proxrserver/proxy.ashx"});
urlUtils.addProxyRule ({ urlPrefix: "https://goldone", proxyUrl: "https://proxrserver/proxy.ashx"});
urlUtils.addProxyRule ({ urlPrefix: "https://goldone:44300", proxyUrl: "https://proxrserver/proxy.ashx"});
have i do something another this
My application running from VB.NET (with F5) starting as "https://goldone:44300"
RobertScheitlin__GISP
Tuba, that looks good for the proxy rules now in the proxy.config you need to do the same for the serverURLs
TubaKumbara
Robert,
This is my proxy.config file which in same directory with proxy.ashx
<serverUrl url="http://goldone" matchAll="true" />
<serverUrl url="http://goldone:44300" matchAll="true" />
<serverUrl url="https://goldone" matchAll="true" />
<serverUrl url="https://goldone:44300" matchAll="true" />
Then there should be no reason for you getting that error then. I am not sure what to tell you.
TubaKumbara
Robert, Thanks for your interests. I know you want to help but i can't to say anything else. I can't debug my codes,
Same sceneview running good when i publish my application to another server. But this is hard to debug from developer console.
I personally do not use Visual Studio for development. I use Atom.io for my js development IDE and just do my debugging in Google Chrome.
TubaKumbara
Thanks for suggest.
TubaKumbara
Robert,
I found the problem. My proxy file is not on my machine. I 've added Some variables to my proxy machine's http response headers.
My fault is that i searching error on my machine since 2 days. Actually error was in proxy machine's proxy web application configuration.
My problem solved and working now. I'm happy.
Thank you again for all help.
Here is the picture where i added variables
