4.32 - ApplyEdits BUG - When Layer is HIDDEN (Codepen added)
1188
03-12-2025 06:58 AM
michaelpoa
Hi esri developers,
There's a bug with applyEdits when Layer X is hidden. When toggling off a layer -> we send a delete all to ArcGIS Api using applyEdits with queryFeatures (all). The delete all functionality is working perfectly when the layer is visible. However, when the layer is toggled off (visibility = false), the clear all will delete all features in memory (arcgis side) but it does not remove the graphics from the map (rendering). Time between processed in memory and renderer on the map is not correct. (Callback issue)
Added a codepen to reproduce this issue.
https://codepen.io/michaelk95/pen/azbLMNK?editors=1000
  1. Updates are being mocked and applied (should be visible)
  2. When toggling "off" layer ship (visibility false) => A clear message is created (console output)
  3. The delete is processed BUT not removed from the map, layer will be hidden
  4. When toggling "on" the layer ship -> a blue rectangle will appear, but arcgis will say there are no features active!
This is quite a big issue and should be fixed?
Thanks in advance
Gr
Michael
UndralBatsukh
Hi there,
I can reproduce the behavior you're describing and will inform you as soon as we have a fix in place. However, I'm curious about why you're using a client-side feature layer in this case. It seems like you're frequently updating features. The StreamLayer, on the other hand, is optimized for handling data that updates at a high frequency.
michaelpoa
Thanks for the investigation! We're also using the feature layer for sporadic updates, as I believe it's the perfect fit for these layers. This issue will still occur with them, I assume. In any case, we'll also look into the stream layer for frequently updating features. Thanks!
UndralBatsukh
Hi there,
This issue is addressed at version 4.34. You can test the fix using our
next version. Here is your codepen updated to point to the next version: https://codepen.io/U_B_U/pen/EaVePpv?editors=1000
Thanks
