3.0 Download
2369
06-21-2012 07:53 AM
KellyHutchins
Esri Notable Contributor
If you've been waiting for the download for version 3.0 of the ArcGIS API for JavaScript it's ready now and available here:
http://www.esri.com/apps/products/download/index.cfm?fuseaction=download.all#ArcGIS_API_for_JavaScri...
JohnCartwright
Thanks Kelly.  I was looking for the test suite that you all use for the API and didn't see it in either the sdk or api downloads.  Am I overlooking it or is it available separately?
I'm interested in more unit test examples as well as what changes need to be made for Derek's test sample (http://blogs.esri.com/esri/arcgis/2012/05/21/writing-unit-tests-for-your-arcgis-api-for-javascript-a...) to work with 3.0.
--john
AxelSchaefer
Hi. There are 2 small errors in the "Install notes for the ArcGIS API for JavaScript".
Configuration options for compact build:
2. Open C:\Inetpub\wwwroot\arcgis_js_api\library\3.0\jsapi\js\dojo\dojo\dojo.js in a text editor [...]
3. Open C:\Inetpub\wwwroot\arcgis_js_api\library\3.0\jsapi\js\dojo\dojo\dojo.js.uncompressed.js [...]
It has to be:
2. Open C:\Inetpub\wwwroot\arcgis_js_api\library\3.0\jsapicompact\js\dojo\dojo\dojo.js
3. Open C:\Inetpub\wwwroot\arcgis_js_api\library\3.0\jsapicompact\js\dojo\dojo\dojo.js.uncompressed.js
The two files for the compact build are under the jsapicompact directory.
HTH and best regards,
Axel
JeffPace
do we need to redownload the api since changes have been made? (i.e graphics, etc.)
KellyHutchins
No you don't need to re-download the API. We created the download version after the api updates so it includes all the fixes.
