1.6 API - set extent from scale
866
03-01-2011 03:02 PM
mdonnelly
I notice in the latest version of the API you can use the function esri.geometry.getExtentForScale and then set the map extent to change scale.
Is there any way to do this in 1.6?
If there is any method to set the map extent based on a given scale number then please let me know.
Regards,
Mark
Regards,
Mark
HemingZhu
Regards,
Mark
1.6 has the same method. http://resources.esri.com/help/9.3/arcgisserver/apis/javascript/arcgis/help/jsapi/namespace_geometry...
