JSAPI 4.x - Feature table widget sort by multiple columns
2379
01-03-2022 11:34 PM
Status: Implemented
Labels (2)
Kishore
ArcGIS JavaScript API 4.x Feature Table widget method sortColumn() allow sort the data based on single field. please provide a similar method which will allow users/developers  to choose/ specify multiple columns to apply sorting on the feature table.
3 Comments
UndralBatsukh
Hi there,
As you mentioned this cannot be done at the moment. We have plans to add support for this. However, I do not have a timeline for this. I will update you once this behavior is supported.
-Undral
Justin_Greco
This was added at 4.23
https://developers.arcgis.com/javascript/latest/4.23/#featuretable
  • Sort multiple fields by setting FeatureTable.multiSortEnabled to true. Setting the direction and new initialSortPriority properties provides control over what column gets prioritized over others when the table initially displays. If these combined properties are not set, the priority defaults to the most recently sorted column. The image below shows the second column, "Enrollment", having a higher sort priority than the "School Name".
BjornSvensson
As mentioned above, this was implemented a part of 4.23 (March 2022).
