The goal of this blog is to provide information and guidance for customers using web applications that are causing browser tab refreshing on iOS devices. This can be any web app, including ArcGIS configurable apps and builders, custom apps built with the ArcGIS Maps SDK for JavaScript, or any other memory or processing intensive app.
The foundational differences between mobile and desktop environments - especially in terms of hardware and memory management - are significant. A mapping app that runs flawlessly on a desktop may not perform well on a mobile device.
When it comes to building web mapping applications, developers often encounter unique obstacles when targeting Safari and all other browsers on iOS. iOS devices often have stricter memory and CPU usage limits compared to their Android counterparts, making web mapping applications more susceptible to browser tab refreshes. Adding to the challenge, iOS 18.4 has introduced a regression leaking image bitmaps that will accelerate the occurrence of browser tab refreshes in certain scenarios. In particular, maps that include a layer using image tiles (raster basemaps, tiled imagery layers) or full-screen images (map image layers) will see the issue more often. We have created a workaround for the iOS issue in the ArcGIS Maps SDK for JavaScript which will be included with version 4.34 and will drastically reduce the refreshing behavior..
This guide will explore these considerations, offer advice for better understanding issues you may be experiencing when running your app on a mobile device, and provide resources for tuning your app for performance.
Web mapping in iOS
While today’s web mapping technology provides rich, dynamic visualizations and interaction with anything from small to very large datasets, they are also inherently memory and processing intensive.
On iOS, memory constraints are more tightly managed by the system to prevent a single tab from affecting the entire device. These limits are process-based, meaning a webpage runs in a dedicated process with a memory ceiling. When a browser tab exceeds the set limit, the system will immediately free up memory by reloading the tab and effectively resetting your application to its default state.
Tuning your ArcGIS map and app for performance
When creating web apps, the goal is to create performant web applications, but this shouldn't come at the cost of other user needs. The key is to balance user expectations with the highest possible performance. The ArcGIS Maps SDK for JavaScript is already optimized for efficient data fetching and visualization, so you should test your application on different devices before beginning any manual optimization. To benefit from constant improvements in CPU and memory usage, always use the most current SDK release. If you still encounter performance issues, consider reducing the amount and complexity of data that your app must display. For example, you can reduce the number of layers in your map and use techniques like client-side aggregation (clustering or binning) to reduce the number of features the map needs to draw. There are several available resources that cover performance optimization techniques for maps and apps, such as:
General Best Practices
To ensure your web mapping app performs well on iOS, consider these recommendations:
Ultimately, understanding the unique constraints and behaviors of iOS is key to building a robust and performant mobile web mapping application.
