Directions Breaking Changes
919
05-31-2023 06:04 AM
Noah-Sager
At version 4.24, the old workflow of creating a Directions widget without a RouteLayer was deprecated, and will be a breaking change at version 4.27, due to arrive in June 2023.
https://developers.arcgis.com/javascript/latest/4.24/#routing
See the Directions widget sample for how it looks to create a Directions widget with a RouteLayer.
https://developers.arcgis.com/javascript/latest/sample-code/sandbox/?sample=widgets-directions
Directions widget code snippet with RouteLayer:
Screen Shot 2023-05-31 at 8.00.33 AM.pngScreen Shot 2023-05-31 at 8.00.33 AM.png
Also at version 4.24, we deprecated several properties on the Directions widget and DirectionsViewModel. We typically remove deprecated things after 3 or more releases. At version 4.27, we are removing the following deprecated properties.
This is a breaking change. The replacement to use is listed alongside the deprecated property.
Version DeprecatedPropertyReplacementVersion Removed
4.24Directions.routeServiceUrl
RouteLayer.url
via
Directions.layer
4.27
4.24Directions.routeSymbol
RouteSymbols.directionLines
via
Directions.layer
4.27
4.24Directions.stopSymbols
RouteStopSymbols
via
Directions.layer
4.27
4.24DirectionsViewModel.highlightSegment
4.27
4.24DirectionsViewModel.routeServiceUrl
RouteLayer.url
via
DirectionsViewModel.layer
4.27
4.24DirectionsViewModel.routeSymbol
via
4.27
4.24DirectionsViewModel.stops
RouteLayer.stops
via
4.27
4.24DirectionsViewModel.stopSymbols
RouteStopSymbols
via
4.27
Contributors
About the Author
Noah Sager is a Senior Product Engineer on the ArcGIS Maps SDK for JavaScript team at Esri. He specializes in labeling, routing, printing, and maybe more. Prior to joining Esri, he mapped utility lines around Appalachia, investigated public restroom access in Chicago, and studied foraging behavior in squirrels in Canada.
