Survey IPS Quality
3351
6
04-28-2023 11:06 AM
SimonMarin
I have been capturing the IPS Quality data, whit the app IPS Setup, whit my device: (Android Samsung S21 FE) but when I try to upload the data, the IPS Setup App Broke up. it doesn't read the services exposed in the AGOL and when the app has been launched, it immediately broke up.
Anybody knows why? or if surveying QA data is necessarily IOS SO?
thanks
Simon Marin
Solution engineer- Esri Colombia
ips_Dejan
Hi Simon,
have you already generated a positioning file from the Survey recordings?
Which build of IPS Setup are you using? When you say "... when I try to upload the data, the IPS Setup App Broke up." what does it mean exactly, did the app crash? Can you please share a screenshot of the experience you are reporting?
SimonMarin
Hi @ips_Dejan.
I don't have any images. 😞
when I said that IPS Setup App has broken up, it means when I want to upload QA data the app closes and I can't upload again because the device shows "ArcGIS Set Up Stops".
So I can't view again the map, and I can't start the test mode. I can't do anything whit the app. I have to uninstall and install it again to app, or delete all apps data to works again
Simon Marin
ips_Dejan
Hi @SimonMarin
usually, when the app crashes unexpectedly you should still have a chance to close it from the app switched (background) and then re-open it without losing cached data.
Can you please try running the whole QR creation workflow again and record the screen while you doing it? This might help us figure out what's causing the issues.
Also, can you please specify which app version are you running? Do you have a different Android device you could do this on?
SimonMarin
OK @ips_Dejan
My device is Samsung Galaxy S21 FE One UI Version 5.1, OS is Android 13
the IPS Setup App version is 1.3.0.
When i have the screen record i'm going to share whit you 😄
Simon Marin
SimonMarin
Hi @ips_Dejan
we try to get a Quality record whit an iOS device. but when we define the path and check on the quality record button the app keeps loading. I send an image in the attachments.
I tried to copy one record and change the attribute Recording Type to make the positioning Quality but kept errors. So we don't know what we must do.
and another question do you have the best workflow to make the surveys correctly whit the IPS Setup app
Simon Marin
ips_Dejan
@SimonMarin
this might indicate there is some issue with the positioning file. what was your impression of IPS performace in Test mode of IPS Setup?
I have verified that QR are working as expected on Android 13 devices we have on our test pile, so that cannot be the reason behind the issues you are experiencing.
